| imadoofus |
 imadoofus Renault 5 Driver
| imadoofus |
| imadoofus |
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 21:37 - 24 Jun 2005 Post subject: |
As above.
Presume to do this you have taken the tank off. Double check that you have connected up the vacuum line to the fuel tap, and you have not disturbed any of the caps for the other vacuum line take offs.
With age the rubber pieces that connect the carbs to the engine can crack. this will allow extra air in and cause a lean mixture.
| imadoofus |
 Posted: 02:21 - 25 Jun 2005 Post subject: |
Running on prime all the time means that should the needle valves stick then most of the contents of the petrol tank will dump themselves into the engine while you are parked.
If the vacuum line is perished then it will allow extra air in after the carbs and cause a lean mixture (and this make the engine run hot). It might not be the actual line, as it could also be the actual fuel tap. Basically in the tap you will find a rubber diaphragm attached to a piston. The vacuum of the intake is used by the tap to suck the piston across and thus open a passage to allow fuel to pass.
If the vacuum pipe or the diaphragm is partially holed then the vacuum is not as strong and the piston might not be pulled across properly.
Note that the air leak would only affect one cylinder. However a lack of fuel from the fuel tap not opening fully would affect all cylinders.
The fuel tap rebuild kits are not expensive. We replaced one recently in Charlottes GPZ500 and it was quite cheap (cannot remember how much, but under £10 I think).
| imadoofus |
 Posted: 13:49 - 25 Jun 2005 Post subject: |
Sounds like it is the diaphragm. There is probably also a rubber O ring in there. One side of the diaphragm is subject to a vacuum while the other side has a vent to fresh air on it.
Suspect if both were gone you might have problems with it running very rich on one cylinder.
Think the best thing to do is to take the fuel tap off and strip it down and check the bits. They normally come apart fairly easily.
| imadoofus |
The last post was made 21 years, 124 days ago. Instead of replying here, would creating a new thread be more useful? |
