difference between 20w-40 and 20w-50?
imadoofus
PostPosted: 17:07 - 24 Jun 2005    Post subject: difference between 20w-40 and 20w-50? Reply with quote
as of now, I have mixed 20w-50 with the earlier existing engine oil. The recommended one is 20w-40.
The bike seems exceptionally hot nowadays even after a small spin.. with the downpipes being very hot and all.. I know they get hot, but now I think its getting hotter than usual.
Anything else that controls the engine temeprature other than the presence of engine oil?
And I havent fiddled with the air/fuel mix yet, so i doubt that its running leaner.
PostPosted: 19:04 - 24 Jun 2005    Post subject: Reply with quote
Doubt it would have much effect on the engine temperature. 20W50 is more viscous than 20W40 when hot.
Which bike is it?
imadoofus
PostPosted: 19:11 - 24 Jun 2005    Post subject: Reply with quote
82 yam 650.
will the throttle speed adjustment affect anything? I havent fooled around with anything else..
and the oil filter hasnt been changed in ages also
and currently the oils have been mixed
PostPosted: 20:15 - 24 Jun 2005    Post subject: Reply with quote
Idle speed will not make much difference. It will heat up more quickly when idling (same amount of cooling air, but more heat generated).
Personally I would change the filter with the oil.
Adjusting the carb idle air screws would make quite a bit of difference and could well make the exhausts hotter if you leaned the mixture off.
imadoofus
PostPosted: 20:19 - 24 Jun 2005    Post subject: Reply with quote
Just to clarify.
There is a small screw in the middle of the 4 carbs, for idle speed adjustment. ANd a screw covered up with some cap or so (that is inaccessible) for the air/fuel mixture.
The small screw is for the idle speed adjustment, i reckon. Will changing that muchly affect the air/fuel mixture?
what does this change? I should then screw it out to make the fuel richer?
ZRX61
Victor Meldrew
PostPosted: 20:45 - 24 Jun 2005    Post subject: Reply with quote
The only thing the idle screw does is move the butterflies or raise the carb slides.... (depending on CV or DC carbs)
PostPosted: 21:37 - 24 Jun 2005    Post subject: Reply with quote
As above.
Presume to do this you have taken the tank off. Double check that you have connected up the vacuum line to the fuel tap, and you have not disturbed any of the caps for the other vacuum line take offs.
With age the rubber pieces that connect the carbs to the engine can crack. this will allow extra air in and cause a lean mixture.
imadoofus
PostPosted: 01:16 - 25 Jun 2005    Post subject: Reply with quote
Kickstart wrote:
As above.
I think it could be the vacuum tube.. ccos when load is put on it, the bike cuts out in the "On" position.
But it runs on the prime position.
Is it bad for the bike to run routinely on prime? until i get the vacuum tube replaced?
and will problems with the vacuum tube make her run hot also?
my sparks are a pale whitish color.. doesnt look very pretty
PostPosted: 02:21 - 25 Jun 2005    Post subject: Reply with quote
Running on prime all the time means that should the needle valves stick then most of the contents of the petrol tank will dump themselves into the engine while you are parked.
If the vacuum line is perished then it will allow extra air in after the carbs and cause a lean mixture (and this make the engine run hot). It might not be the actual line, as it could also be the actual fuel tap. Basically in the tap you will find a rubber diaphragm attached to a piston. The vacuum of the intake is used by the tap to suck the piston across and thus open a passage to allow fuel to pass.
If the vacuum pipe or the diaphragm is partially holed then the vacuum is not as strong and the piston might not be pulled across properly.
Note that the air leak would only affect one cylinder. However a lack of fuel from the fuel tap not opening fully would affect all cylinders.
The fuel tap rebuild kits are not expensive. We replaced one recently in Charlottes GPZ500 and it was quite cheap (cannot remember how much, but under £10 I think).
imadoofus
PostPosted: 07:11 - 25 Jun 2005    Post subject: Reply with quote
I didnt know the fiel taps were as critical. Thanks.
The petcock leaks slightly in the ON position, so i guess I would have to replace it to correct this proble and it might not really be the vacuum hose
thanks
PostPosted: 13:49 - 25 Jun 2005    Post subject: Reply with quote
Sounds like it is the diaphragm. There is probably also a rubber O ring in there. One side of the diaphragm is subject to a vacuum while the other side has a vent to fresh air on it.
Suspect if both were gone you might have problems with it running very rich on one cylinder.
Think the best thing to do is to take the fuel tap off and strip it down and check the bits. They normally come apart fairly easily.
imadoofus
PostPosted: 16:03 - 25 Jun 2005    Post subject: Reply with quote
Oh, you might not have read the other post, but i fixed the problem of 2 cylinders runnning rich. It was a leak in the airbox rubbers. So now all 4 cyliinders are up to norms.. But just the feeling that it is overheating.
It has an O-ring and the part diagrm doesnt necessarily mention a diaphragam. Is it inside the Lever, cock? Diagram attached. I plan to take it apart today. I was going to find an O-ring and replace it
Parts
13 4H7-24524-00-00 LEVER, COCK 1
14 3H3-24523-00-00 VALVE 1
15 4H7-24525-00-00 PLATE, LEVER FITTING 1
16 3H3-24518-00-00 WASHER, WAVE 1
17 98501-03008-00 SCREW, PAN HEAD 2
18 3H3-24534-00-00 O-RING
PostPosted: 18:18 - 25 Jun 2005    Post subject: Reply with quote
Mmmm, maybe a new diaphragm is not available from Yamaha. If you look at the back of the fuel tap I would suspect you will find 3~4 bolts. Undo these and the back of the fuel tap will come off to reveal the diaphragm (do this with the tank empty as otherwise fuel will pee out all over the place).
The last post was made 21 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 82.61 Kb
