exhaust thread buggered
mirax
PostPosted: 17:41 - 25 Jun 2005    Post subject: exhaust thread buggered Reply with quote
the exhaust thread where the studs go into the exhaust manifold on my dt is buggered half of it is chewed up whats the best way in fixing it ?
Simonbt
PostPosted: 18:18 - 25 Jun 2005    Post subject: Reply with quote
easiest way - Get a new barrel
Is it just the studs that are stripped or the actual manifold?
alains
PostPosted: 18:30 - 25 Jun 2005    Post subject: Reply with quote
you can either taper it at the over diameter (7x100 for 6 , 8x125 for 7, 10x150 for 8 ) or buy special helicoïdal thread (very expensive)
mirax
PostPosted: 18:34 - 25 Jun 2005    Post subject: Reply with quote
yeah its the manifold thread not the stud thread
viper61
PostPosted: 18:40 - 25 Jun 2005    Post subject: Reply with quote
Or you could just try a tap down it with loads of wd40 or even better some proper cutting compund such as rocol (i think). Depends how bad the thread really is. We have done this at work on mullered manifold threads before and has worked fine. You may have to use a die on the stud though as well.
Rob
mirax
PostPosted: 19:04 - 25 Jun 2005    Post subject: Reply with quote
how much would i expect to pay if it needs a helicoil ?
ZRX61
Victor Meldrew
PostPosted: 19:50 - 25 Jun 2005    Post subject: Reply with quote
about $10 if I was doing it..
If it's held on by studs how did you manage to muller the thread inside the barrel?
tatters
Exxon Valdez
PostPosted: 19:55 - 25 Jun 2005    Post subject: Reply with quote
the nut probley sezied due to rusting, so when he tryed to un-do the nut the stud extracted out of the cyclinder.
mirax
PostPosted: 20:13 - 25 Jun 2005    Post subject: Reply with quote
thats the 1, nut got propper stuck on and had to extract the stud, all went fine until i put it back in. it was tigntening ok untill the stud felt loose used hardly any pressure did what i was meant to tightened it by hand then the fucking stud ate the thread
viper61
PostPosted: 02:31 - 26 Jun 2005    Post subject: Reply with quote
Perhaps you can drill and re-tap then re-stud with a different size stud. You will have to drill the other exhaust fitting too though. Sounds like a helicoil or timesert would be best though as the other guys say. You can get the kits yourself but if you dont use them much it may be cheaper to take to a dealer or garage / workshop and see if they can do it for you.
ZRX61
Victor Meldrew
PostPosted: 06:02 - 26 Jun 2005    Post subject: Reply with quote
You can get studs with different size threads on the ends. So ya could (ferinstance) have M6 on outside for the nut & M8 screwed into the barrel.. saves fucking about with helicoils...
mirax
PostPosted: 12:39 - 26 Jun 2005    Post subject: Reply with quote
cheers guys for the insight might try and go for the option ZRX61 metioned
viper61
PostPosted: 12:40 - 26 Jun 2005    Post subject: Reply with quote
Yeah that would probably be easier i'll agree. Worth looking around for some on the net perhaps they may be cheaper. Just measure the one you need.
The last post was made 21 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 74.02 Kb
