PLEASE HELP!!
trafficdodger
PostPosted: 13:20 - 26 Jun 2005    Post subject: PLEASE HELP!! Reply with quote
I have just taken out the inlet restrictor and when i have come to put it back together there are three tubes from the carb i dont know where they go if you stand at the back of the bike there is one tube on the left on top of the carb and one on the right on top as well and one from the bottom.
_________________
Present bike Yamaha R6
alains
PostPosted: 13:36 - 26 Jun 2005    Post subject: Reply with quote
the 2 top pipes plastic are snuffling pipes as the third one , they go across the tray through 2 holes .
trafficdodger
PostPosted: 13:41 - 26 Jun 2005    Post subject: Reply with quote
Also when i turn the bike on i think it is the power valve it moves about half inch in a circle is this normal. thanks so none of those pipes are attached to any thing. i have also found a really fat pipe almost looks blue much bigger in diameter do you know where this one goes.
Thanks alot for all your help i really do appreciate it
alains
PostPosted: 13:55 - 26 Jun 2005    Post subject: Reply with quote
about the valves , the servo-motor has a pulley visible under the right side of the tank . each time of you put the key on the servo moves the valves full openning , then when you start engine the servo closes the valves and stay there as long as you are under 6500 RPM , if you go over the servo open the valves . this is to have the max torque at low RPM . all the process is controled by an electronic box called RC valves control unit sited under the carb in the vertical plane front of the battery . this box check the valves position function of your RPM every ~3 seconds and will keep them open except if your RPM go under 4500 then it will reclose and the process restart .
you have also on the carb 2 big rubber black pipes . the bigger one is the petrol pipe coming from the tank , the other is the 2T oil pipe coming from the pump .
trafficdodger
PostPosted: 14:03 - 26 Jun 2005    Post subject: Reply with quote
is there a big pipe that goes on to the air boxing
trafficdodger
PostPosted: 14:05 - 26 Jun 2005    Post subject: Reply with quote
alains
PostPosted: 15:00 - 26 Jun 2005    Post subject: Reply with quote
yes , this is in case water going on top of the air box to drag it out
The last post was made 21 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 50.8 Kb
