Tyre curse or am I just unlucky?
Was the tyre cursed?
Cursed
52%
 52%  [ 9 ]
You're just unlucky
47%
 47%  [ 8 ]
Total Votes : 17
tintin
PostPosted: 11:37 - 29 Jun 2005    Post subject: Tyre curse or am I just unlucky? Reply with quote
Three weeks ago I had to replace my rear tyre as it had a nail sticking out of it. Two weeks later (last Thursday) I park up and find a nail in the new tyre, I take it to FWR and they are able to plug it (£20). Yesterday I find another nail sticking out of the tyre! Mad
I took it to FWR on the way home and the boss man did the repair himself as everyone else was busy. He was a bit reluctant as he said it was too close to the edge, I pointed out that it was nearer the middle than the other repair they had already done. Got the repair done (another £20), I would have rather not, but with only about 500 miles on the tyre I didn't really want to replace it. I started to drive home but after about 5 miles the bike started feeling weird, I stopped and looked but couldn't see anything wrong and carried on very carefully. 10 miles later it was getting worse and worse, bloody tyre was almost flat. I limped to a garage filled the tyre up, got home and in half an hour it was flat as a pancake. Filled it up and checked it over but I couldn't find a leak, but it was flat again about an hour later.
This morning I took a footpump with me and stopped every 10 miles to top it up. When I got back to FWR the manager was a bit defensive and started telling me he never thought it was a good idea to repair it in the first place but finally agreed to knock £20 off the cost of fitting a new tyre. I was asked to sit in the waiting room and he came in 5 mins later and said they had found another hole in the tyre, hmmm nothing to do with a bad repair then?
So I've decided that this tyre must be cursed - after all it was a Diablo!
Twisted Evil
I hope I have better luck with the new one Neutral
The older I get the better I was
feef
Energiser Bunny
PostPosted: 11:55 - 29 Jun 2005    Post subject: Reply with quote
is there anywhere on your regular routes that could have nails or something about. Pass any builders merchants? DIY shops? Building sites?
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Zoffo
PostPosted: 11:57 - 29 Jun 2005    Post subject: Reply with quote
Ultaseal Thumbs Up
No more punctures Very Happy
https://hyperbikes.forumsplace.com/
LustyLew
PostPosted: 12:08 - 29 Jun 2005    Post subject: Reply with quote
Don't worry. When I used to commute to work on the bike I'd usually have at least 3 nails in the back tyre. I'm sure they are put there deliberately!
I ended up putting 'Slime' in the rear just to stop and slow punctures. Never went above 50 anway so I left most nails in there!
ali-b
PostPosted: 12:43 - 29 Jun 2005    Post subject: Reply with quote
I had 3 punctures in one day - 2 in the back on the way to work, 1 in the front on the way from work...roundabouts were NOT fun...
I had the 2 rear punctures plugged while at work, and just had both the tyres replace the next day after getting the front puncture as I figured these tyres were, in fact, cursed...Evil or Very Mad
Alex.
PostPosted: 13:11 - 29 Jun 2005    Post subject: Reply with quote
Maybe you ought to fit an inner tube? At least that is easy to repair.
People will throw their hands up and say you shouldn't but I have used and abused numerous tubless fitment sports tyres on my supermoto before now with no ill effects.
PostPosted: 13:31 - 29 Jun 2005    Post subject: Reply with quote
Zoffo wrote:
Ultaseal Thumbs Up
Yep, saves the loss of pressure until you are going fast enough for it to be really dangerous.
To go with what Stinkwheel says, you can get specific heavy duty inner tubes to be used with tubeless tyres (the insides of tubeless tyres are not finished as smoothly as a tubed tyre).
Zoffo
PostPosted: 14:18 - 29 Jun 2005    Post subject: Reply with quote
Kickstart wrote:
Zoffo wrote:
Ultaseal Thumbs Up
Ultraseal is tested to 150 mph.
Don't confuse Ultraseal with slime. its totally different (and should be for £25 a shot). Not only does it prevent deflation but you can carry on using the tyre for its normal lifetime. No need to change just coz you get a nail in it. I watched a demonstration of this stuff. Guy with a 6mm drill bit just kept drilling holes in the tyre all the time he was talking and the tyre didn't lose any pressure. He then rode on the tyre and even did a few stunts Very Happy
PostPosted: 14:49 - 29 Jun 2005    Post subject: Reply with quote
Cannot remember whether it was Ultraseal or one of the others that Col had, but it was bright pink (and Slime is green I think) so quite likely it was Ultraseal. Worked OK until he went a bit quick when it peed out and covered the rear suspension. Not a problem on a short speed run, but having slippery stuff on a deflating wheel at speed is not a good idea.
Also not a good idea to have stuff in there which will hide puncture which would otherwise indicate damage to something like the side walls of the tyres.
Also, do you really want to add over half a kilo of unsprung weight to the bike?
Personally I really do not think a liquid good that sets to a certain level will really provide a plug that is anything like as effective as a proper repair to a tyre.
Yes I do think the stuff can be useful, but not prepared to use it on anything that will be used at a sustained high speed. Maybe something used for green laning.
Zoffo
PostPosted: 15:36 - 29 Jun 2005    Post subject: Reply with quote
https://www.avsco.co.uk/ultraseal-motorcycle-tyre-protection.htm
Quote
Ultraseal Total Tyre Protection
Protect those expensive tyres & the inconvenience of a roadside puncture
Will permanently seal punctures caused by puncturing objects up to 6mm
The seal is guaranteed for the life of the tyre
Punctured – Ultraseal seals giving a telltale mark
Speed tested up to 150mph
Tested for stability up to 40,000 miles
Perfect air retention state in the tyre
Helps extend tyre life.
Improved handling of the machine
Dampens vibrations, reduced suspension failure
A 700 ml DIY bottle will do 2 or 3 tyres
Seems to answer most of your questions Keith.
As for the unsprung weight. I did 3000 miles around France and often at speeds well in excess of 150 mph. with no vibes or handling probs even on the crazy mountain hairpins where even the panniers were touching down
PostPosted: 15:51 - 29 Jun 2005    Post subject: Reply with quote
Afraid that there advertising claims do not answer any of my questions (and the Slime that you say is different is also claimed to be tested at 150mph). Some of those claims strike me as being major bull, such as "improves handling" (no, extra unsprung weight will make the suspension have a harder time).
As to having a front wheel blow out, my whole feeling is that I would rather know about the air leak at low speed, rather than waiting to find the effect at high speed.
lurker
PostPosted: 15:55 - 29 Jun 2005    Post subject: Reply with quote
I put ultraseal in a dunlop d207 which had a small nail in it.
I got a bottle after my brother used it to plug a hole on his rear tyre which seemed good.
Pulled the nail out, put the ultraseal in and pumped the tyre up at which time the pink stuff and small rubber pieces came spewing out the hole.
The garb about it sealing holes the size of drill bits may work during demonstrations(but i dont know why) but my personal experience with the stuff was a bit disappointing.
btw i followed the instructions toe the letter.
Suzuki
Roger
PostPosted: 15:58 - 29 Jun 2005    Post subject: Reply with quote
For some reason punctures seem to come in groups.
I had a puncture, had a new tyre fitted, and a week later had another nail sticking in the new tyre.
So annoying.
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
Zoffo
PostPosted: 16:29 - 29 Jun 2005    Post subject: Reply with quote
Your supposed to put it in before the puncture not after FFS
feef
Energiser Bunny
PostPosted: 18:11 - 29 Jun 2005    Post subject: Reply with quote
perhaps they mean "improves handling in the event of what COULD have flattened your tyre, but it's now still inflated cos of our goo"
a
tintin
PostPosted: 18:33 - 29 Jun 2005    Post subject: Reply with quote
Personally I don't like the idea of riding round with anything in my tyres, ultraseal, green goo, nails, repairs or inner tubes (can't see any point in an inner tube in a tubeless tyre).
All of them sound like they might be a potential problem at 100mph - is it worth the risk?
I would rather live with getting a puncture, it's a pain in the arse and a pain in the wallet. I didn't like repairing the tyre the first time so part of my brain is now going to be a lot happier knowing I've got a new tyre.
The last post was made 21 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.75 - MySQL Queries: 15 - Page Size: 101.32 Kb
