clutchless shift
paulthewitt
PostPosted: 13:09 - 29 Jun 2005    Post subject: clutchless shift Reply with quote
ok i guess this is the best section for it.
we all know that clutchless gear shifts can be done on a bike (tricky between 1st and 2nd though.) i saw a quote at the bottom of someones signature that quoted somone else saying:
Can you clutch'less gear change in a car?
i was wondering whether this was a joke or derogatory or something. just thought i'd say yes you can clutchless shift in acar. a policeman i knew was telling me how about a year ago. its one of there advanced techniques, and is a little more tricky than on a bike. its the same theory, when accelerating just ease off the power for a split second allowing the torque between the wheels and the engine to align, then move up a gear. obviously trickier as youve got to move across the box aswell. but hey, it can be done.
dont do it on the way down through gears though!
anyone ever tried it on an hgv??? Twisted Evil
Paul
DISCLAIMER - I am not liable for your gearbox if you destroy it attempting the procedures described in the above paragraphs!
feef
Energiser Bunny
PostPosted: 13:34 - 29 Jun 2005    Post subject: Reply with quote
can be done going up OR down the gears, but down is Much harder,as you have to rev the engine to the correct higher revs while you're shifting the stick acros the box.
Clutchless shifting in an ordinary car does nothing for quicker acceleration, as the larger flywheel means engine speed drops slower than that of a motorcycle, so takes longer for the speeds of the input shaft and the box itself to match up.
with a lightened flywheel, it's a much slicker affair, but clutcheless shifting in a car is never going to be as quick as on a bike.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Chr!S
PostPosted: 13:37 - 29 Jun 2005    Post subject: Reply with quote
Yup can be in a car. Much Harder to get right and smooth though.
PostPosted: 14:22 - 29 Jun 2005    Post subject: Reply with quote
Clutchless changes are certainly possible in a car. However you are going to get some hideous grinding noises when you get it wrong. Just as easy going up or down the box.
Friends clutch cable snapped in his Renault 19 in a dodgy area of Manchester so he landed up driving for about 15 miles doing clutchless changes to get somewhere less risky to get it fixed.
killa
Won't Shut Up
PostPosted: 14:28 - 29 Jun 2005    Post subject: Reply with quote
Bit stupid in a car TBH.
Tell you what is impressive, doubling the clutch (Mr McQueen in bullit), oh that Shelby noise.
PostPosted: 14:50 - 29 Jun 2005    Post subject: Reply with quote
To an extent you need to do the same thing when doing clutchless gear changes, just not operating the clutch between each stage.
In a suitable vehicle it would be a quicker way of changing gear.
Villers
PostPosted: 16:29 - 29 Jun 2005    Post subject: Reply with quote
Had the exact same problem in my Cupra. The clutch cable snapped taking the pedal box with it. I was halfway up a dual carriageway hill and stuck in heavy traffic. I just had to wait for the right time, put it in second, floor it and turn the key - off it went with so much battery drain that the clock went back to 00:00. At this point I was aware of clutch-less shifting but not clutch-less starting off so I did it in second. Managed to get to a lay by and wait for much later on (15,000 people leaving the site where I work between 3.30pm and 6pm!!!) then limped it home, dropping into neutral and then revving whilst sliding the gear home. Wasnt that bad.
Cant really see the advantage in a floorin' it situation as you could easily miss a gear in the car and end up looking quite the fool!
DukeRed
PostPosted: 16:32 - 29 Jun 2005    Post subject: Reply with quote
Doubling the clutch? Have wondered what it was since fast and furious.
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
Villers
PostPosted: 17:01 - 29 Jun 2005    Post subject: Reply with quote
What? You trying to tell me you don't live life one quarter mile at a time? Laughing
killa
Won't Shut Up
PostPosted: 17:10 - 29 Jun 2005    Post subject: Reply with quote
I had a go once in an escort, but as Keith said you need a powerful car with a clean cutting box.
You are flooring it, dip clutch, almost simultaneously giving it a bit of gas, while putting it up a cog and then back on with clutch. The effect, if done properly is a much smaller amount of rev’s lost while changing.
See Bullit, that car chase I watched about 20 times.
PostPosted: 17:12 - 29 Jun 2005    Post subject: Reply with quote
Double declutch. Basically putting the clutch down, shifting into neutral, lifting the clutch pedal, blipping the throttle, pushing the clutch down again and shifting into the gear below before releasing the clutch pedal again.
Idea is that doing this you spin up the input shaft into the gearbox to match that of the output shaft in the gear you are changing into. Smoother gear changes and less wear on the synchromess (or less/ no grinding on a box with no / worn synchromesh).
killa
Won't Shut Up
PostPosted: 17:17 - 29 Jun 2005    Post subject: Reply with quote
No doubt you get a rating.
Grrrrrr!!
garth
PostPosted: 17:21 - 29 Jun 2005    Post subject: Reply with quote
yup, just to annoy you though Killa. Laughing
g a r t h
loply
PostPosted: 17:46 - 29 Jun 2005    Post subject: Reply with quote
I do clutchless changes in my car all the time.
1) Push the gear lever into neutral
2) Allow the revs to fall to the correct speed of your desired gear (if going up gears) OR Raise the revs to the required amount if going up gears
3) Gently push the gear lever into the required gear and at the right RPM the lever should pop in perfectly
If you get a grinding noise the revs are too high or too low, in which case dip the clutch and put it in normally. You kinda have to get used to the exact revs to get the gear to slip in, else youll keep messing it up.
Between 4th and 5th on a motorway or whatever is really easy though, just make sure you dont let the revs fall too low.
Yamaha SZR660 Caution to the wind, the throttle pinned!
loply
PostPosted: 17:55 - 29 Jun 2005    Post subject: Reply with quote
Just to clarify double declutching (aka double clutching), the purpose of this is to make DOWN shifts smoother, not for shifting upwards.
If you tried to shift from 5th @ 70mph to third it would cause all kinds of problems (lurching, gearbox wear, engine braking).
If you double declutch you could go from 5th @ 70mph to 3rd without any problems what so ever, without loosing any speed at all, and totally smooth.
The purpose is twofold:
1) Prevent gearbox wear
2) When entering a corner at high speed it wont unsettle the suspension, whilst still maintaining high revs
Not much use on the road really, but good fun never the less.
feef
Energiser Bunny
PostPosted: 18:04 - 29 Jun 2005    Post subject: Reply with quote
double-de-clutching was really only "needed" in the days before synchromesh, where you could easily TRY and mesh gears at the wrong speed.
Now it's only real benefit is making downshifts a little smoother
a
DukeRed
PostPosted: 18:17 - 29 Jun 2005    Post subject: Reply with quote
I see now Thumbs Up
ts50x0
is double clutching then, like blipping the throttle when changing down on a bike???
loply
PostPosted: 18:41 - 29 Jun 2005    Post subject: Reply with quote
ts50x0, yeah basically the same thing, the only difference being that you put the gear into neutral and take your foot off the clutch during the blipping (whereas on a bike you just hold the clutch in).
cqueen
PostPosted: 20:32 - 29 Jun 2005    Post subject: Reply with quote
you mean Mr CQueen in his fiat punto Cool
killa
Won't Shut Up
PostPosted: 13:42 - 30 Jun 2005    Post subject: Reply with quote
Momentum, speed and weight as you know are incredibly different on a bike than a car. When you change up on a bike bliping the throttle wont make alot of difference as the engine can easily carry the next load and carry you up the required speed. (depends also on power of the bike i.e a 50cc is to tame)
Double clutching in a car keeps the revs up, when you change normally there is a slight fluctuation in motion physics. Double the clutch quickly and smoothly and you should notice a bit of extra push. (also depends on the cars power)
feef
Energiser Bunny
PostPosted: 13:56 - 30 Jun 2005    Post subject: Reply with quote
it's nothing to do with the engine coping with the load. It's to do with a smaller, lighter flywheel on a bike, meaning engine revs drop MUCH faster than on a car, so with only a momentary throttle closure, the revs drop to match the geared shaft speed of a higher gear.
that extra "push" is your clutch plates wearing faster than needs be as they absorb the difference in speed bewteen the engine and gearbox.
better to get engine speed matched to gearbox sped for that gear, and just shift as normal. Doesn't overstress the clutch, or any drive components, that spiked loading of effectivly dumping the clutch on the move would do.
killa
Won't Shut Up
PostPosted: 14:01 - 30 Jun 2005    Post subject: Reply with quote
Sorry man I kinda just briefed it, Its just to get the idea.
PostPosted: 14:25 - 30 Jun 2005    Post subject: Reply with quote
Given how jerky a gear change is without blipping the throttle (in a car or on a bike) I am surprised that so many people do not seem to be doing it.
Must mean crash helmet finishes are improving. Otherwise they would all have marks in the paint on the back from being nutted by the pillion every time the rider changed down a gear.
Dam_buster
PostPosted: 14:36 - 30 Jun 2005    Post subject: Reply with quote
yea i asked the question to binge, and he just laughed at me. i was just thought, hey it can be done on a bike why not a car?
lol..
thanks for proving him wrong guys! Thumbs Up Mr. Green
JIM
Yamaha R6 5EB, BMW 328i Touring, BMW 328i Coupe
The last post was made 21 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 138.02 Kb
