| paulthewitt |
 paulthewitt World Chat Champion
| feef |
 feef Energiser Bunny
 Posted: 13:34 - 29 Jun 2005 Post subject: |
can be done going up OR down the gears, but down is Much harder,as you have to rev the engine to the correct higher revs while you're shifting the stick acros the box.
Clutchless shifting in an ordinary car does nothing for quicker acceleration, as the larger flywheel means engine speed drops slower than that of a motorcycle, so takes longer for the speeds of the input shaft and the box itself to match up.
with a lightened flywheel, it's a much slicker affair, but clutcheless shifting in a car is never going to be as quick as on a bike.
a ____________________ Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating |
| Chr!S |
 Chr!S Nitrous Nuisance
| Kickstart |
 Kickstart The Oracle
 Posted: 14:22 - 29 Jun 2005 Post subject: |
Clutchless changes are certainly possible in a car. However you are going to get some hideous grinding noises when you get it wrong. Just as easy going up or down the box.
Friends clutch cable snapped in his Renault 19 in a dodgy area of Manchester so he landed up driving for about 15 miles doing clutchless changes to get somewhere less risky to get it fixed.
| killa |
 killa Won't Shut Up
| Kickstart |
| Villers |
 Villers World Chat Champion
| DukeRed |
 DukeRed World Chat Champion
 Posted: 16:32 - 29 Jun 2005 Post subject: |
Doubling the clutch? Have wondered what it was since fast and furious. ____________________ Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com |
| Villers |
 Posted: 17:01 - 29 Jun 2005 Post subject: |
What? You trying to tell me you don't live life one quarter mile at a time?  ____________________ RS125 > CBR6 > SV650S > ZX636R > GSX1300RZ Hayabusa > 06 RSVR Mille > SV1000S > Street Triple 765 RS |
| killa |
 killa Won't Shut Up
| Kickstart |
| killa |
 killa Won't Shut Up
| garth |
 garth World Chat Champion
 Posted: 17:21 - 29 Jun 2005 Post subject: |
yup, just to annoy you though Killa.
g a r t h ____________________ You ain't a has been if you never was |
| loply |
 loply World Chat Champion
 Posted: 17:46 - 29 Jun 2005 Post subject: |
I do clutchless changes in my car all the time.
1) Push the gear lever into neutral
2) Allow the revs to fall to the correct speed of your desired gear (if going up gears) OR Raise the revs to the required amount if going up gears
3) Gently push the gear lever into the required gear and at the right RPM the lever should pop in perfectly
If you get a grinding noise the revs are too high or too low, in which case dip the clutch and put it in normally. You kinda have to get used to the exact revs to get the gear to slip in, else youll keep messing it up.
Between 4th and 5th on a motorway or whatever is really easy though, just make sure you dont let the revs fall too low. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| loply |
 Posted: 17:55 - 29 Jun 2005 Post subject: |
Just to clarify double declutching (aka double clutching), the purpose of this is to make DOWN shifts smoother, not for shifting upwards.
If you tried to shift from 5th @ 70mph to third it would cause all kinds of problems (lurching, gearbox wear, engine braking).
If you double declutch you could go from 5th @ 70mph to 3rd without any problems what so ever, without loosing any speed at all, and totally smooth.
The purpose is twofold:
1) Prevent gearbox wear
2) When entering a corner at high speed it wont unsettle the suspension, whilst still maintaining high revs
Not much use on the road really, but good fun never the less. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| feef |
| DukeRed |
 Posted: 18:17 - 29 Jun 2005 Post subject: |
I see now  ____________________ Enjoy Life There's Plenty of Time to be Dead
| ts50x0 |
 ts50x0 Spanner Monkey
| loply |
 Posted: 18:41 - 29 Jun 2005 Post subject: |
ts50x0, yeah basically the same thing, the only difference being that you put the gear into neutral and take your foot off the clutch during the blipping (whereas on a bike you just hold the clutch in). ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| cqueen |
 cqueen World Chat Champion
| killa |
 killa Won't Shut Up
| feef |
 Posted: 13:56 - 30 Jun 2005 Post subject: |
| killa wrote: | | ts50x0 wrote: | is double clutching then, like blipping the throttle when changing down on a bike??? |
Momentum, speed and weight as you know are incredibly different on a bike than a car. When you change up on a bike bliping the throttle wont make alot of difference as the engine can easily carry the next load and carry you up the required speed. (depends also on power of the bike i.e a 50cc is to tame) |
it's nothing to do with the engine coping with the load. It's to do with a smaller, lighter flywheel on a bike, meaning engine revs drop MUCH faster than on a car, so with only a momentary throttle closure, the revs drop to match the geared shaft speed of a higher gear.
| Quote: | Double clutching in a car keeps the revs up, when you change normally there is a slight fluctuation in motion physics. Double the clutch quickly and smoothly and you should notice a bit of extra push. (also depends on the cars power) |
that extra "push" is your clutch plates wearing faster than needs be as they absorb the difference in speed bewteen the engine and gearbox.
better to get engine speed matched to gearbox sped for that gear, and just shift as normal. Doesn't overstress the clutch, or any drive components, that spiked loading of effectivly dumping the clutch on the move would do. ____________________ Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle
| killa |
 killa Won't Shut Up
| Kickstart |
 Posted: 14:25 - 30 Jun 2005 Post subject: |
Given how jerky a gear change is without blipping the throttle (in a car or on a bike) I am surprised that so many people do not seem to be doing it.
Must mean crash helmet finishes are improving. Otherwise they would all have marks in the paint on the back from being nutted by the pillion every time the rider changed down a gear.
| Dam_buster |
 Dam_buster Crazy Courier
 Posted: 14:36 - 30 Jun 2005 Post subject: |
yea i asked the question to binge, and he just laughed at me. i was just thought, hey it can be done on a bike why not a car?
lol..
thanks for proving him wrong guys!
JIM ____________________ Yamaha R6 5EB, BMW 328i Touring, BMW 328i Coupe |
The last post was made 21 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
