| Ric |
 Ric Could Be A Chat Bot
| numark1 |
 numark1 Scared of girls
 Posted: 01:04 - 30 Jun 2005 Post subject: |
Do as much of the simple stuff as you can do and then get the garage to do the rest. Check your service manual to see.  |
| gsxrboy |
 gsxrboy Scooby Slapper
If you want a job done properly do it yourself. It knobs me right off the amount you have to pay for a service. ____________________ www.predatorsport.co.uk Paintball arena located between Northampton and Milton Keynes |
| Ric |
| Kram |
 Kram World Chat Champion
| Kram |
| Ric |
| mr.z |
 mr.z World Chat Champion
 Posted: 02:40 - 30 Jun 2005 Post subject: |
Don't imagine that haveing a dealer/shop do the job it will be done propperly... they dont have to ride it, they are ALLWAYS trying to get stuff out of the way and will often cut corners/bodge stuff into place, loose bits e.t.c.
Theres good ones but not many, only time i get the mechanic down the road to do anything is if it requires a tool i dont have or cant afford at the time.
Most stuff should be fairly easy on a zxr, the clutch should be easy enough too, i helped a mate do an engine swap and a few engine innards and its not so bad if you have all the propper gear..
Drummer - You mean valve clearences, on some its easy to do (locknut adjustments) on shims they can be fiddle (from what i have been told) and you need to order them or have them handy to change (if it needs it) easy to do really but also easy to mess up and its not somthing you want to bugger up, try and get help from a knowlageble friend.. Carb balancer i payed £50, takes 5 minutes to check and 30minutes or so to adjust, easy to do that one... ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
The last post was made 21 years, 93 days ago. Instead of replying here, would creating a new thread be more useful? |
