| illusion |
 illusion Scooby Slapper
| simon1221 |
 simon1221 World Chat Champion
| Hex |
 Hex Party Boy
 Posted: 18:50 - 08 Jul 2005 Post subject: |
Its just where the fluid has taken up the space from where the brake pads have worn.
As long as the amount isn't too low I wouldnt worry about it. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
| illusion |
| Guest |
 Guest Brolly Dolly
| Finglonga |
 Finglonga World Chat Champion
| easy |
 easy Derestricted Danger
| Guest |
 Guest Brolly Dolly
| Kram |
 Kram World Chat Champion
| easy |
| Kram |
| Finglonga |
 Posted: 09:41 - 10 Jul 2005 Post subject: |
| easy |
 Posted: 10:07 - 10 Jul 2005 Post subject: |
Or Google Bleeding motorcycle brakes . Although this could find someone who isn't happy with the brakes on their bike.
I found this and this were usefull, but if you want to get precise instructions investing in a Haynes may be better.
As Finglonga says it's fairly straightforward to do and after you've done it just give it a few 1st gear hard stops to make sure there's no problems and then go easy on the braking for the next couple of days. Like I said above not being able to stop on a bike is not fun, so a couple of days should show if there are any long-term problems.
If there's air getting back in again, then it's time to service the calipers, lever/pedal and maybe replace the lines, just for overkill.
 Posted: 12:54 - 10 Jul 2005 Post subject: |
Bleeding brakes is not difficult (although bleeding an empty system can be a nightmare).
However on the FZR you have a standard Yamaha brake system, so the calipers are probably the problem. If they are spongy they chances are you need to clean the calipers out thorough, especially behind the seals. Possibly replace the seals as well.
By the way, the only common fluid that does not absorb water like a sponge is DOT 5 (notDOT 5.1, which is very similar to DOT 3 and DOT 4), and it is very rare to find that used. Does seem to get used on older vehicles that are doing a very low mileage as you can pretty much just stick it in the system and forget it afterwards (does not absorb water, so that is the main reason for replacing brake fluid out of the way). However it is a pain to use properly as you need to make sure every trace of water is out of the system, as otherwise the water will settle to one point in the system, boil easily causing spongy brakes when used hard, and cause corrosion.
The last post was made 21 years, 110 days ago. Instead of replying here, would creating a new thread be more useful? |
