Clutch pin
Shamrock
PostPosted: 21:42 - 08 Jul 2005    Post subject: Clutch pin Reply with quote
I was replacing the clutch worm which is what drives the clutch pin into the engine thus engaging the clutch.
However I cant seem to get the clutch to engage. Im thinking the clutch pin isnt going far enough into the engine.
Any ideas why?
Guest
PostPosted: 11:04 - 09 Jul 2005    Post subject: Reply with quote
Bike? Then we can maybe find a fiche with some pictures of what's where Wink
Shamrock
PostPosted: 13:54 - 09 Jul 2005    Post subject: Reply with quote
Sorry. Its an SV650S!
Guest
PostPosted: 21:54 - 09 Jul 2005    Post subject: Reply with quote
Hmmmmmmm, conventional Suzuki push rod operated clutch, they don't normally give trouble.
https://67.15.65.225/spst/2001%20SV650,S/08.gif
The worm drive (17) pushes the two pushrods against the operating bit (16) and moves the presure plate against the springs.
If you've had the worm drive to bits then you may need to wind it round so far before bolting it back on to sort of pre-load it. If you pull up on the split bracket that holds the cable nipple you should feel it starting to push against the pushrods.
Looking at the side of the engine, I'd guess the cable operating arm should be at about the four o'clock position so that when the cable's adjusted up it pulls it upwards, screwing the worm drive out onto the pushrod.
Screw the cable adjusters at both ends all the way in. then undo locknut #19 and screw the grub screw #18 in until you feel it hit the pushrod. Back it off 1/4 turn and tighten the locknut.
Now take up nearly all the cable slack on the adjuster at the sprocket cover, leaving the adjuster on the bar lever to take up the last little bit of play.
Shamrock
PostPosted: 05:30 - 10 Jul 2005    Post subject: Reply with quote
Nice one Guest.
Thats a great help!
Ill give it a try. Thumbs Up Very Happy
The last post was made 21 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.72 - MySQL Queries: 13 - Page Size: 43.31 Kb
