| Craggles |
 Craggles Traffic Copper
| iCraig |
 iCraig World Chat Champion
 Posted: 13:46 - 11 Jul 2005 Post subject: |
They do 'go' after a wee bit. I have had to replace the ignition switches on two GPZ500s before. They click 'on' but don't actually switch on. Wiggling the key about can help but you eventually need to replace the switch.
Of course, another reason for the key to go straight in and out is if someone has screwdrivered the ignition at some point. Try a different key in it (anything that fits in the hole) if this turns, chances are the bike has been nicked at some point. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Craggles |
 Posted: 22:16 - 11 Jul 2005 Post subject: |
It you do need to change the lock they can be a pig to do. You will need to take off the top yoke and then drill out the bolts (or if you are lucky you can tap it round with a chisel).
They are held on normally with shear bolts. These are bolts where the head is in 2 pieces, one bit smooth and round and the other bit with a hex on it for a spanner, and this bit snaps off when the bolt gets tight.
 Posted: 23:04 - 11 Jul 2005 Post subject: |
Not on mine, maybe a different model. The bolts are hex heads and recessed into the top yoke. You can get on them but only with a really thin walled socket. The one from my 1/4" drive socket set fitted round them with a little gentle persuasion (nylon hammer to the rescue once again). Didn't even have to take the yoke off by using appropriate extension bars.
It is entirely possible that it is just the bottom part of the switch that is worn. Once it is off you can seperate the lock from the switch itself, there is a tag on the plastic switch that is turned by a slot in the bottom of the metal lock. From looking at my old one the plastic switch is awffy rickety looking, you get the impression that the points where it clicks over from one position to another don't quite line up properly with the key positions. In theory you should be able to order this as a seperate part although when I have done it in the past, I just bought a second hand lockset from the breakers.
Retaining the original lock barrel would be preferrable then your key would still fit everything else too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Craggles |
| Craggles |
The last post was made 21 years, 89 days ago. Instead of replying here, would creating a new thread be more useful? |
