Clutch Problem
dransy
PostPosted: 20:18 - 16 Jul 2005    Post subject: Clutch Problem Reply with quote
I own an rs 125, When i set off in a morning or when ever it has just been warmed up i can set of fine, but after ive been on it for a while and the temperature increases i can never set of right.
I either rev its ass off or set of and it bogs down, but i have noticed that if im stood at lights and the temperature rises my revs rise aswell.
I could be holding throttle so its at say about 3 or 4 thou and it will just rev up on its own even though i havent moved the throttle so im always setting off to slow or to fast but this only happens when ive been out on it for like 30 mins +
any ideas?
cheers
marc
kb-zxr
PostPosted: 22:39 - 16 Jul 2005    Post subject: Reply with quote
Maybe worn clutch plates? As bike gets hotter so does oil, making the oil thinner. Nail it in 3rd or 4th and see if the clutch slips. This might be the problem. Wait for some more replies first in case Im wrong Cool
dransy
PostPosted: 01:37 - 17 Jul 2005    Post subject: Reply with quote
Thanks kb
anyone else want to reply?
hehe
yambabe
PostPosted: 01:52 - 17 Jul 2005    Post subject: Reply with quote
OK, probably stating the obvious here but you have taken the choke off all the way haven't you?
dransy
PostPosted: 01:54 - 17 Jul 2005    Post subject: Reply with quote
Posted: 00:52 - 17 Jul 2005 Post subject:
yeah i havent needed to use the choke with it been nice and warm
yambabe
PostPosted: 02:00 - 17 Jul 2005    Post subject: Reply with quote
Have you got an electric fan on your radiator? What temp is it showing? An RS125 should be between 84 & 89 once it has warmed up.
yambabe
PostPosted: 02:03 - 17 Jul 2005    Post subject: Reply with quote
Further info from my Aprilia-certified mechanic:
If it does this, if you put the choke on a little bit then take it off again your idle should drop right down & it shouldn't rev up again. Give this a try & let us know if it helps?
dransy
PostPosted: 02:16 - 17 Jul 2005    Post subject: Reply with quote
ok cheers , going out tomorrow so ill try it then
thanks alot Thumbs Up
priller
PostPosted: 03:09 - 17 Jul 2005    Post subject: Reply with quote
74 & 79 is closer.
The last post was made 20 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.28 - MySQL Queries: 13 - Page Size: 61.37 Kb
