Race cdi?
dransy
PostPosted: 11:36 - 19 Jul 2005    Post subject: Race cdi? Reply with quote
What do they actually do?
A few people have reccomended i get one for my rs 125 , what is the difference between a race cdi and a normal cdi?
cheers
marc
PostPosted: 11:50 - 19 Jul 2005    Post subject: Reply with quote
The standard RS125 cdi unit has a large amount of ignition retard between 5000 and 6000rpm to cause a massive flat spot. They can easily be modified to remove this.
The race cdi units do not have this ignition retard. They may also have the timing played with slightly elsewhere.
There is also a programmable unit available, but not sure what can be changed on it.
dransy
PostPosted: 12:04 - 19 Jul 2005    Post subject: Reply with quote
Ah cheers keith
As for the flat spot at 5-6 thou you scrape out the back of the cdi and break the link then re seal it?
This was alredy done on my bike when i purchased it i unscraped it all and made sure it had been done propperly , after im out and about for abit the flat spot comes back.
Is it impossible to get rid of it completely?
houlsby
PostPosted: 12:05 - 19 Jul 2005    Post subject: Reply with quote
hi, the race cdi's for the rs are real good quality. dont pay craigs prices off 125cc. he banned me because i can get them for 210 race cdi duel programable. they do take away the flat spot at 5-7k so it makes riding them eisier. it also helps that you can use it like a car ecu (so ive been told) so on your comp you can make power curves ect. if you want to look at getting a cdi i can probably sort you out with one. (they are the same as cmp racings i get them from his supplier but i sell them at less)
PostPosted: 12:16 - 19 Jul 2005    Post subject: Reply with quote
The flat spot should not come back. Basically the original cdi unit contains both ignition maps and cutting the bridge just tells it to use the map without the ignition retard.
You will almost always get a flat spot at half peak power on any bike in a high state of tune. The exhaust works well in a limited range when the pressure waves bounce back at a perfect time to suck the next lot of exhaust gases out of the cylinder. As the pressure waves bounce at pretty much a constant speed at about half peak power they are doing their best to keep the next lot of exhaust gas in the cylinder.
If it is a really bad flat spot (ie, the bike will barely pull through it in any gear) then it may be that the bridge was not cut in the cdi properly, or something in the sealant is shorting it out.
dransy
PostPosted: 12:18 - 19 Jul 2005    Post subject: Reply with quote
When im going up a hill it is incredibly bad it doesnt go threw it at all i have to keep down gearing all the time.
On a flat road its fine and it goes straight threw it.
Ill just have to check it again make sure its sealed propperly
PostPosted: 12:25 - 19 Jul 2005    Post subject: Reply with quote
Sounds normal to be honest. It is a small highly tuned 2 stroke and at 5000rpm it is probably making 8hp and dropping dramatically as the revs drop. Just keep it in a lower gear.
Craig_
PostPosted: 12:27 - 19 Jul 2005    Post subject: Reply with quote
Houlsby - You buy off electrex world right? Well i you think i'd trust them to be my supplier you've got another thing coming they don't have a clue about the racing CDI's and never seem to get back to people.
I think you should cut all your slanderous comments untill you know the true facts, and the true prices i pay, trade price for me on the Dual Curve CDI is around £234.97 + P&P and i get them from a place called HCR who HPI put me onto.
Also i do hope your regestered with the Inland Revenue as self employed if your selling all these parts, you wouldnt want the tax man catching you out. Not to mention insurance just incase the CDI causes the bike to seize, throw's someone off it and their seriously injured.
Once again if you think i pay less than £210 to buy those CDI's in you have got the total wrong end of the stick and are spouting off (once again) without knowing the true facts. And you were banned for constantly breaking the "no blatent advertsing" rule, and then been abusive to admin's and moderators.
VAG Cars - www.vagcars.co.uk - North East VAG Owners Club
houlsby
PostPosted: 12:30 - 19 Jul 2005    Post subject: Reply with quote
im having the same problem. keep it in a lower gear and get the plug and components changed. on mine the plug is misfiring at low revs and splutters up hills ect. so i either clutch it to 7k or drop a gear if i can.
cheers kieran
houlsby This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Craig_
PostPosted: 12:39 - 19 Jul 2005    Post subject: Reply with quote
Flaming on another forum, do you think i joined just to insult you? Check when i regestered i've been on here longer than you and have more than likely met more members on here in RL than you.
I'm just stating facts that you dont know what your talking about.
houlsby
PostPosted: 12:49 - 19 Jul 2005    Post subject: Reply with quote
you make me laugh boy.
Craig_ Posted: 12:39 - 19 Jul 2005 Post subject:
i know you joined ages ago. im saying stop ruining another thread. this guy is trying to find out about cdi's if you want to sort this all out the get my msn addy an we will discuss this in real time not on a public forum.
Craig_
fair doos, i have never said i know what im on about but cant you remember just starting up? or were you some sort of genious as soon as you came into this.
Adam_P
PostPosted: 12:55 - 19 Jul 2005    Post subject: Reply with quote
Where's the button I click to point out that you're both now just spamming this thread, and, in turn, this forum.
Take the spat elsewhere, its boring, redundant and crap!
Rolling Eyes Thumbs Down Middle Finger
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
Jrod
Page 3 Girl
PostPosted: 13:26 - 19 Jul 2005    Post subject: Reply with quote
It's shifting down, down gearing is changing the size of the sprocket.
rschris This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
nora2004
PostPosted: 00:27 - 20 Jul 2005    Post subject: Reply with quote
Dear god, like Craig has ever ripped anybody off, his prices are spot on, you muppet!
rschris
PostPosted: 00:33 - 20 Jul 2005    Post subject: Reply with quote
obviously you aint shopped around then nora, your part of craigs kiss ass crew anyway.
as i say i aint gonna post anymore on the subject as the issue is finished with, and i dont want to spoil this GOOD FORUM so please sssssssshhhhhhh
houlsby
PostPosted: 00:34 - 20 Jul 2005    Post subject: Reply with quote
Rolling Eyes Angelic Liar
nora2004
The youth of today! Shocked
ash t
PostPosted: 00:44 - 20 Jul 2005    Post subject: Reply with quote
Woffle
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
Dom_
Points Mean Prizes
PostPosted: 00:52 - 20 Jul 2005    Post subject: Reply with quote
Not wanting an argument but if you look up, Craigs prices are cheaper than those websites you just listed...
Also, Craig is running a business, not making a quick back hander.
I suggest you all take the argument off the forum and learn about what your arguing about before jumping in to conclusions, and houlsby, use the friggin spell check button.
rschris
PostPosted: 00:54 - 20 Jul 2005    Post subject: Reply with quote
dom all that has been said everywhere i go i seem to get stuff alot cheaper than craig sells them for and he flames up and lies.
and houlsby cant help its were he comes from Razz Razz Razz
Dom_
Points Mean Prizes
PostPosted: 00:57 - 20 Jul 2005    Post subject: Reply with quote
Dman i hate getting involved in arguments, but, you say this, have you got any link as to where you can get identical parts to craig and they are cheaper??
And wheres he lieing?
Anyhoo, i'm leaving before i get involved too much.
Dom. Mr. Green
rschris
PostPosted: 01:02 - 20 Jul 2005    Post subject: Reply with quote
dom mate aint arguin lol. were discussing. just i aint gonna give links out of items were i may be selling myself soon.
and craig was lying saying he was only supplier of jl in the uk wen theres another 2
Craig_
PostPosted: 13:12 - 20 Jul 2005    Post subject: Reply with quote
Once again, Chris, posting once un-informed. Ex-Tech UK is Micron, they no longer supply two stroke system due to the small lack of demand. Apex do indeed import JL's and I've never said I was a sole importer, however I tend to have the exhausts in stock where possible where as Apex have them made to order which can take a few weeks for the system to arrive.
And if you had ever seen any e-mail I sent to Tom Risby (A.K.A Rizo9) you will have seem me say time and time again that I don't offer the fork anodising service as a CMP service I can have it done for him as a favour. The delay was caused by the anodiser, who agrees to do them on the side to save hundreds.
Tom was informed of all this, and when they were still not back I said I have a set recently fitted to my own bike which he could have. I then proceeded to strip down my own bike of its forks and send them to him so he got them in time for his birthday.
Name me another business that would take that option, every other one would keep the person waiting. Not to mention when I made this decision I was away racing and all I did all weekend was reply to Tom's text's when I didn’t have to.
You seem to make it out I rip everyone off, and everyone is un-happy with my services however how come there’s only one person who has used me that has turned on me for no reason, well the main reason is so you and houlsby like him. You and houlsby have never even used my services so you have no right to comment.
If I did rip people off why and I still in business? And why do I have hundreds of customers willing to back me up? And yes, I am a 100% legal business, registered with the Inland Revenue, Insured, and just about finalised VAT Registration which isn’t a legal requirement at the moment.
Once again you idle threats don’t bother me, if you really want to “chin” me you know I go to Sherburn often, and as I’ve said once before I’m there at least once or twice a month on a Wednesday night.
The last post was made 21 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 136.21 Kb
