HELP!
nc30 chick
PostPosted: 19:04 - 20 Jul 2005    Post subject: HELP! Reply with quote
Help me please someone!
I cant get me bike working Crying or Very sad
I broke down last Friday along the motorway, she lost power and as i pulled over the engine cut out and wouldnt start again. Eventually managed to get a tow home.
Anyway, hubby pulled the bike apart and checked the obvious and it turns out the starter motor had given up the ghost and also the breather pipe going into the fuel tank had got trapped between the tank and the bars so when we took the pipe off there was a lot of air which probably caused her to lose power.
So anyway, we have now got a new starter motor and just put it on and she still not working. She clicks but doesnt try to turn over.
We have checked the solenoid and there is power getting to that and its clicking and there is power going to the terminals on the rectifier. Strange thing is when we put the lights on main beam and push the starter the dash lights go off. We are at a loss, I dont know anyone who knows about bike engines and I really dont know what to do as I cant get her anywhere as she wont start. Oh and the battery is fine as its fairly new and I have charged it up too.
Question is, 1) is there anyone near Bracknell whos willing to come and have a look at her? 2) Does anyone have any other ideas? 3) Does anyone know of someone near here who can help?
Cheers in advance
From one very sad biker whos not biking at the mo Confused
matty8887
PostPosted: 19:07 - 20 Jul 2005    Post subject: Reply with quote
Could the battery be the problem, maybe needs charging or a new battery. If the lights go out when full beam and starter motor are used then this would sugest there isnt enought power to go around.
This is just my opinion though, could be wrong.
Lone-Wolf
PostPosted: 19:09 - 20 Jul 2005    Post subject: Re: HELP! Reply with quote
Wotcha.
Lights going out normally means an earth fault somewhere. Try a heavy gauge wire from the battery to the starter motor, effectively bypassing the solenoid. If it still doesn't spin, then there is fault between the battery negative and earth.
Cheers.
L.W. - www.moonshiners.org.uk
feef
Energiser Bunny
PostPosted: 19:11 - 20 Jul 2005    Post subject: Reply with quote
even tho the battery is newish, it's worth checking it is holding a charge. If the started died with a short, it could have discharged the battery very rapidly, and killed it.
have you tried jumpstarting it?
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
nc30 chick
PostPosted: 19:17 - 20 Jul 2005    Post subject: Reply with quote
We are just getting some jump leads to try it out .
conpants
PostPosted: 19:28 - 20 Jul 2005    Post subject: Reply with quote
the fuse went on my cb500 causing the exact same kind of problem
not in the fuse box but in the starter relay! try that it also meant my battery wasnt charging
swaffs
PostPosted: 19:35 - 20 Jul 2005    Post subject: Reply with quote
Have you tried bump starting it?
when my battery was boogered, I was able to bump it no problem?
Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness."
PostPosted: 19:37 - 20 Jul 2005    Post subject: Reply with quote
So you press the starter, the solenoid clicks and the lights go out.
This implies to me that either.
a) The battery is about dead, the starter motor is drawing all the power but it is still not enough to turn over the engine.
b) There is a dead short somewhere between the solenoid and the starter motor. Sure he got the terminals the right way round and the live isn't touching the frame anywhere?
nc30 chick
PostPosted: 19:40 - 20 Jul 2005    Post subject: Reply with quote
Well it looks like we might have found the problem, we found the battery earth lead has a break in it. Hopefully that has fixed it. She starts now so we will see what happens.
Thank you all so much for your advice, your all stars Very Happy Thumbs Up
bazza
PostPosted: 19:47 - 20 Jul 2005    Post subject: Reply with quote
33 mins from 1st post to resolution.
Now that's what I call a result!
Thumbs Up Mr. Green Thumbs Up
nc30 chick
PostPosted: 19:54 - 20 Jul 2005    Post subject: Reply with quote
it starts on the button NOW i just hope we fixed the problem
The last post was made 21 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 71.95 Kb
