I have just got a honda cg 125 2000 model
Thedan
PostPosted: 21:01 - 22 Jul 2005    Post subject: I have just got a honda cg 125 2000 model Reply with quote
Hi all i am new to the forms and have just purchased my first bike with my cbt sheduled for tuesday next week. using ebay i feel i have come across a good example with only 2504 miles on the clock and generally good condition. i will post a picture and tell me what u think bikes like this normaly go for. bearing in mind i only have one years prior documentation and servicing was carried out by the previous holder.
can some one tell me instructions on what kind of servicing has to be done or problems are known for 2000 models of cg125 so i can rectify them.
Many thanks Dan
desperate need to get mobile, need to get fast, need to get sorted!
Andy C
Tree Seeking Missile
PostPosted: 21:05 - 22 Jul 2005    Post subject: Reply with quote
welcome! from what i hear about cg125 they seem bulletproof...after all its a honda!!! hope you find somw good info on hear and maybe try the search tool to get info on cg125!
hope you enjoy her!
mr.z
PostPosted: 21:22 - 22 Jul 2005    Post subject: Reply with quote
Welcome to the forum Thumbs Up
I'd trust a home machanic more than a dealership overall, i'd not worry too much about it...
Anything over £800/900 would be over the top..
I'm not sure which year they brought out the electric start (pretty sure yours will have) or the disc brakes, but they are a bonus if its got them..
Problems... brakes are rubbish, so take you time and keep them in top condition ALL the time (adjustment pretty much) thats about it Wink
Have fun Thumbs Up
Thedan
PostPosted: 14:27 - 23 Jul 2005    Post subject: Reply with quote
Thanks i managed to bag the bike for £600 i think it is a fair price. Overall condition is ok and i have only a kick start no electric start.
Is it possible to fit a electric start to a 2000 model cg125 with kick start only?
Many thanks will use the search.
mr.z
PostPosted: 14:44 - 23 Jul 2005    Post subject: Reply with quote
It is possible but WAY more hassle than its worth... cheapest way would probably be an engine swap!
Think of it this way, kickstarts dont have nearly as much to go wrong, if your battery is flat you can still start your bike!
When you get used to useing it (get the seller to show you how to start it, it can be tricky) its no problem...
Have fun, let us know how you get on Thumbs Up
Thedan
PostPosted: 13:32 - 03 Aug 2005    Post subject: Reply with quote
Sorry i have not had any internet and still dont so i am doing this from work Smile.
The kick-start is fine starts always by second go. my clutch is quite ferocious though as once i start and hold the clutch down and then select 1st gear the bike will jump forward a bit and click loudly. Does anyone know what this could be?
Also the clutch has 3 positions for the CG125 how should i operate this correctly at the min i leave it on the lowest (towards the Footpegs) and if i switch it all the way up (towards the seat) when it is on the bike cuts out.
I have also heard that the bike can be made electric only i do not know how to proceed, so that i can make it electric and kickstart.
Many thanks
Dan
JeffT
PostPosted: 13:39 - 03 Aug 2005    Post subject: Reply with quote
That is standard mate.
Most bikes will "jump" a little when you put them in to first. I wouldn't worry about it
MattShill
PostPosted: 15:58 - 03 Aug 2005    Post subject: Reply with quote
This is normal apparently, it does the same for mine.
All the way down is no choke, starts easily like this in most conditions. The next one up is half choke, use this one if it's cold or it's not starting for some other reason. I find that it will be harder to start with low fuel since it's gravity fed, or I might be imagining it. Anyway, middle position usually starts it. The final position, all the way up, should be used in extreme conditions when nothing else will start it. This is because the mixture is so rich it can drown the engine and stall it, but it can be used to start it in really cold conditions. As soon as it's going you should put it half way to idle while it warms up before cutting the choke all together once it'll run under it's own steam and you're ready to go.
Hope that helps.
Living life in the second overtaking lane!
'98 Kwak ER-5
biggerjohn
PostPosted: 16:25 - 03 Aug 2005    Post subject: Reply with quote
There is a very good chance you will do you CBT on a CG125 so make sure the instructor give you a very good run through on all the bikes controls and operation including the basics of maintenance.
You may well be able to do the CBT on your own bike if you can get it to the test centre legally and have the MOT and proof of insurance this would help boost your knowledge of your bike and riding it no end.
veeeffarr
PostPosted: 16:31 - 03 Aug 2005    Post subject: Reply with quote
I have a 2001 CG125 and yeah, I usually put half choke on, starts first time, give it a few revs (Don't rag it) keep it from dying... then after about 30 seconds snap it onto no choke and keep the revs up a little bit again, should take about 90 seconds to get running nicely Smile
Nice colour, wish I couldve got mine in silver but alas Smile
Mine's a 2001 Y plate with 4000 miles, paid £875 so looks like you've got yourself a bargain dude, not much difference between our two models! Smile
(By the way,only just figured this out but the steering lock is undernearth the headstock, you need to push the smaller key you got with ur ignition into it and push the lock in, and twist it Smile)
Thedan
PostPosted: 12:49 - 04 Aug 2005    Post subject: Reply with quote
Yes mate i no about the headlock i snapped the key in mine. Got that all sorted now though. So the choke is correct then i thought it was mashed but looks like thats fine then. Cheers for the information. So i should keep the choke all the way down towards the floor when normal conditions, middle if its a little bit cold, and the top setting towards the seat for extreme conditions and when i do this normally the engine should cut off? as this is what happens.
Many Thanks
Dan
mchaggis
PostPosted: 13:41 - 04 Aug 2005    Post subject: Reply with quote
Laughing Laughing
Forgive me for I am a cynic, born from experience. Wink
Regular oil changes (every 1000 miles) will help, but your engine will still go pop (even if only minorly) when it gets to 30-35k. Don't forget these things spend almost all of their time flirting with the redline. It is still possible to have all the same problems with them as any other bike, you have to maintain it properly, or it will fall to pieces.
Oil changes are the key, but chain maintenance, cleaning + oiling the air filter, cleaning/ changing the plug, keeping valve clearances right, plus keeping on top of all the fasteners which will shake themselves loose are important too.
I must not be a troll...
Mmmm, Guinness
MattShill
PostPosted: 18:34 - 04 Aug 2005    Post subject: Reply with quote
I'd like someone to shoot a Honda, just to test how bulletproof they really are. Not mine, obviously, but it'd be an interesting test.
One more thing - make sure you don't ride it with the choke on at all, or once you hit about 5-6000rpm the engine won't be able to cope with all the fuel it's getting and you lose all power. Scarey stuff if you don't realise what's going on.
'98 Kwak ER-5
The last post was made 21 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.14 - MySQL Queries: 13 - Page Size: 81.56 Kb
