Clutch help?
 Topic moved: from General Bike Chat to The Workshop by Kickstart (25 Jul 2005 - 18:29)
dransy
PostPosted: 17:40 - 25 Jul 2005    Post subject: Clutch help? Reply with quote
Right i need to know how to alter the biting point of my clutch, when i alter it at the end where the lever is when i put it in gear it stalls not enough clutch on?
Anyway i have to release my clutch lever nearly all the way out and its a pain in the rear as my little finger allways catches on the ball of the lever and the glove gets caught.
How can i alter it so i only have to let it out about untill i can get the bite point?
Will i follow the cabel down and tighten it up something up?
rs125 btw
cheers people.
PostPosted: 19:29 - 25 Jul 2005    Post subject: Reply with quote
There is an adjuster down on the clutch cover. This might need adjusting. I will dig out some instructions when I get home.
Guest
PostPosted: 21:40 - 25 Jul 2005    Post subject: Reply with quote
i wrote this out for a Suzuki but it should sort you out....
Back the adjusters right off at both ends of the cable.
On the sprocket cover, remove the rubber bung. Loosen the locknut with a ring spanner and screw the grub screw in until it bites on the end of the clutch push-rod, then back it off 1/4 of a turn. Tighten locknut.
Take up adjustment on cable at the sprocket cover end while holding the clutch lever - you'll feel it starting to get pulled tight. When it's pulled back to about 10mm from fully 'home', tighten the locknut on the cable adjuster at the sprocket cover.
Now make final adjustments at the lever end leaving a little slack - this'll give you something to play with if it tightens in use like if you're crawling through heavy traffic.
sickpup
Old Timer
PostPosted: 00:46 - 26 Jul 2005    Post subject: Reply with quote
Well that'll confuse anyone without a pushrod clutch like on an RS125. Laughing
Guest
PostPosted: 12:56 - 26 Jul 2005    Post subject: Reply with quote
You could always download the owners manual from here ..........
https://www.serviceaprilia.com/public/lum/index.asp?l=Rs%20125
and check the relevent pages..
or you could sit on your arse and just post sarcastic replies like some twats do Middle Finger
sickpup
Old Timer
PostPosted: 17:27 - 26 Jul 2005    Post subject: Reply with quote
Ah fuck it I apologise if I'm wrong. Laughing
dransy
PostPosted: 21:35 - 26 Jul 2005    Post subject: Reply with quote
cheers guys Thumbs Up
The last post was made 21 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 16 - Page Size: 53.01 Kb
