Airbox
Jrod
Page 3 Girl
PostPosted: 17:46 - 26 Jul 2005    Post subject: Airbox Reply with quote
If air can get in between the carbs and airbox (where they join) will it affect the running of the bike?
instigator
PostPosted: 17:53 - 26 Jul 2005    Post subject: Reply with quote
Erm....yes....one would most definetely presume...
stu_m
PostPosted: 20:05 - 26 Jul 2005    Post subject: Reply with quote
yup it will make it run lean
as you are increasing the airflow to the carbs
alains
PostPosted: 20:36 - 26 Jul 2005    Post subject: Reply with quote
certainly not !
PostPosted: 20:51 - 26 Jul 2005    Post subject: Reply with quote
Will make it run a bit oddly, but not that much.
swampy
PostPosted: 20:58 - 26 Jul 2005    Post subject: Reply with quote
I dont think it would it would make it run lean, as it is before the carb. I.e the air flowing into the carb controls fuel flow into the air stream as a result of the venturi effect. If the leak is after the carbs then you would then be leaning the mixture as there would no more petrol being added at this stage. You can run a bike without an air filter or box if you so wish (although not recommended). However you would then be introducing air with particles of dust etc which is not good for cylinder barrels. The symptoms of an air leak are over revving (often alarmingly so), and lack of power. Thumbs Up
alains
PostPosted: 21:45 - 26 Jul 2005    Post subject: Reply with quote
you're right but not if the leak is prior the carb , after the carb it's dangerous
instigator
PostPosted: 21:54 - 26 Jul 2005    Post subject: Reply with quote
I ran my bike once I first restricted it, and it wouldn't go over 3k. Then I remembered to put the airbox in. Embarassed
Get it fixed, boyo.
PostPosted: 01:22 - 27 Jul 2005    Post subject: Reply with quote
With the airbox you also have the tubes from the carbs into the airbox. These pipes are of a specific length. With the airbox off you loose this effect and this can have very strange effects.
bish777
PostPosted: 13:43 - 27 Jul 2005    Post subject: Reply with quote
Highly tuned engines and/or ones jetted quite lean will suffer without an airbox fitted.
Richer jetted and less high tuned machines wont suffer as much.
Its best to make sure everything is properly clamped on and sealed. Silicon sealer is great for keeping airboxes sealed.
Removing the airbox and fitting individual filters can be done but requires alot of messing with jetting.
GSXR1100J
Jrod
Page 3 Girl
PostPosted: 20:23 - 27 Jul 2005    Post subject: Reply with quote
It's just when I put my airbox back on I wasn't 100% that it seals airtight to the carbs. I never noticed it before so thought it was something new. It still all runs fine so it's cool. Cool
Cheers everyone! Smile
The last post was made 21 years, 89 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 67.77 Kb
