bike has just died help me
matphillipsuk
PostPosted: 16:55 - 27 Jul 2005    Post subject: bike has just died help me Reply with quote
hi my nsr has just died it sounded like the chooke was on when i was riding and then it just started slowing down but still going. then when i pulled over turned it off it started up ok ran for a about half a mile then did it again backfired now it wont start again! any ideas ? please dont say it has anything to do with the cylinder and piston
alains
PostPosted: 17:44 - 27 Jul 2005    Post subject: Reply with quote
put a new plug and try . if it works you must clean tank , air box foam , carb and adjust mixture . plugs do not like too rich or too oily mixture
matphillipsuk
PostPosted: 18:04 - 27 Jul 2005    Post subject: Reply with quote
nope nothing trying to turn over but not sparking into life. any ideas? if it does need a new piston and cylinder kit, other than gaskets seals is there anything else i will need to replace
simon1221
PostPosted: 18:10 - 27 Jul 2005    Post subject: Reply with quote
How easy is it to turn the engine over? eg bumpstart?
As it is too easy then no compression.
bish777
PostPosted: 18:57 - 27 Jul 2005    Post subject: Reply with quote
not wishing to sound condescending, but you havent run out of fuel have you?
GSXR1100J
kingsknight
PostPosted: 20:07 - 28 Jul 2005    Post subject: Reply with quote
sounds like you ran out of fuel my friend Smile
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
matphillipsuk
PostPosted: 16:24 - 29 Jul 2005    Post subject: Reply with quote
nope im not that dumb lol yeah pleanty of fuel in there tried to start it agian today and it started but when i took it along my street it wouldnt let me rev above about 6000rpm with out sounding like it had done the other day. any ideas?
alains
PostPosted: 16:44 - 29 Jul 2005    Post subject: Reply with quote
look your servo-motor pulley sequence , you may have a bug either on cdi or r/c valves unit . key on : valves on high . start engine : valves on low when idle . valves on high starting about 6000 rpm
if the pulley do not move after starting , this a sign of no infos comming from the cdi through the red/white wire .
matphillipsuk
PostPosted: 15:10 - 30 Jul 2005    Post subject: Reply with quote
ok so tried starting again today wont start without being bump started. i took the spark plug out placed my thumb over the hole and pressed the starter it blew my thumb off the hole that suppose to be a good sign of compression isnt it? so would that rule out a problem with the piston?
The last post was made 21 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 59.01 Kb
