Sticky gears
lionelc
PostPosted: 22:01 - 27 Jul 2005    Post subject: Sticky gears Reply with quote
I have a Hongdou CG125 - it has been fine, but recently it has started to 'stick' in gear. In particular I have trouble between 3rd to 2nd. What do you think is causing this? clutch? gear selector? - I guess I need to be brave and open her up - but where do I get spares from if necessary? Rolling Eyes
Regards, LC Smile
Slinn84
PostPosted: 23:15 - 27 Jul 2005    Post subject: Reply with quote
Before you start taking it apart check your chain. if its too tight then this can make shift changes awkward.
another thing would be to try a clutchless gear change to see if that works, i.e accelerate with your foot putting a bit of pressure on the gear lever, then shut the throttle and let ur foot come right up and change gear. if this works then it my be your clutch cable that needs attention
lionelc
PostPosted: 00:13 - 29 Jul 2005    Post subject: Reply with quote
Thx for advise. Certainly I can change gear without using the clutch...is this not correct?
Regards, LC Smile
Slinn84
PostPosted: 00:56 - 29 Jul 2005    Post subject: Reply with quote
yeah u should be able to change without your clutch. if u can change without your clutch but its sticky when your using your clutch lever then your cable may need attention, it may be slack or coming loose.
this is only a minor thing tho to check, just to make sure you've eliminated the simple stuff before you start messing with the clutch pads or gearbox
The last post was made 21 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 38.81 Kb
