my mates rs50
on_one
PostPosted: 20:52 - 27 Jul 2005    Post subject: my mates rs50 Reply with quote
right it use to cut out when the revs went bolow 5k then last week its would'nt run at all, he found out it was the coil so i knew my mate had a spare so i picked it up earlyer and we tried it the spark plug sparks when its out and on the head but when we bump start it starts up and runs then cuts out
any ideas whats wrong
simon1221
PostPosted: 21:18 - 27 Jul 2005    Post subject: Reply with quote
What colour is the spark plug?
Do you have good compression?
DNA50 (sorry) ->> TZR125l >> GPZ500S
on_one
PostPosted: 22:00 - 27 Jul 2005    Post subject: Reply with quote
its a brand new plug and the compression seems ok it had a new top end about 7k ago
TOM M
PostPosted: 17:56 - 28 Jul 2005    Post subject: Reply with quote
try adjusting the idle using the adjuster on the carb (it will say how to do this in the manual)
Now owner of a 1200 Bandit
TOM M
PostPosted: 17:57 - 28 Jul 2005    Post subject: Reply with quote
or even take the spark plug out and see if it is gapped correctly Thumbs Up
If the gap is too big, the spark could be too weak
on_one
PostPosted: 18:48 - 28 Jul 2005    Post subject: Reply with quote
cheers for the replys thing is it cuts out while revving it Confused (could that be the fuel or something) and the spark looks fine when its held on the head
TOM M
PostPosted: 20:16 - 28 Jul 2005    Post subject: Reply with quote
try looking at your fuel lines to see if there is any kinks etc in them which would restrict fuel flow, or check to see if there is a blockage
on_one
PostPosted: 20:25 - 28 Jul 2005    Post subject: Reply with quote
the main fuel lines ok as its getting into the carb, could it be the reeds
houlsby
PostPosted: 02:06 - 29 Jul 2005    Post subject: Reply with quote
right, on my 125 you cant rev it straight as it warms up without the choke on. so when you start it, keep choke on for 10-20 secs, then take choke of and rev to about 4k, also are you sure it has petrol in?
on_one
PostPosted: 09:51 - 29 Jul 2005    Post subject: Reply with quote
its got a K&N filter on so there isnt a choke on it we did get it warmed up to what should be warmer enough to tick over last night from all the times we bumped it , its got half a tank of petrol
simon1221
PostPosted: 11:30 - 29 Jul 2005    Post subject: Reply with quote
Really? Wow thats gotta be a pain in the arse to start in the winter.
Try putting the standard filter back on?
The last post was made 21 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 7 - MySQL Queries: 13 - Page Size: 64.6 Kb
