Revving up madly on neutral and clutchin
imadoofus
PostPosted: 02:17 - 29 Jul 2005    Post subject: Revving up madly on neutral and clutchin Reply with quote
Hi,
my bike nowadays revs up madly to about 5-6Ks on neutral or on clutching. Especially after its warmed up sufficiently. I hit the kill switch around this range or switch into gear and pull out, so i dont know how high it will rev till.
why could this be?
thanks
Kram
PostPosted: 02:49 - 29 Jul 2005    Post subject: Reply with quote
if you use no throttle in gear, what does it do?
your idle speed is probably to high
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
DM
PostPosted: 03:00 - 29 Jul 2005    Post subject: Reply with quote
I doubt it's his idle speed that's the problem since it requires a decent amount of turning to get it idling that high and the problem sounds like it popped up, more or less. Sounds like a manifold leak to me...
bish777
PostPosted: 03:03 - 29 Jul 2005    Post subject: Reply with quote
sticky throttle cable most likely.
GSXR1100J
imadoofus
PostPosted: 04:50 - 29 Jul 2005    Post subject: Reply with quote
its not the idle speed. I have the idle speed properly.
And i think this happens mostly only after it has run for sometime..
Can someone pease explain what a sticky throttle mean? I know that my throttle is slightly loose and I have about 1/8th of a turn oh the throttle thats loose.. and it moves the slider-thingy on the carbs only after that.
Manifold leak? You mean the carb rubbers? would cause raised revs?
stu_m
PostPosted: 08:10 - 30 Jul 2005    Post subject: Reply with quote
sounds like throttle sticking
check to make sure the cable isnt frayed at either end and lube the cable
swampy
PostPosted: 11:56 - 30 Jul 2005    Post subject: Reply with quote
Yep an air leak in the carb rubbers between the carb and the head would cause it to over rev alarmingly. If your carbs attach to the head directly, I'd change the gasket as it may be torn. Best not to ride it until the problem is sorted as if you do have an air leak, the mixture will be lean causing the engine to run hot.
imadoofus
PostPosted: 18:55 - 31 Jul 2005    Post subject: Reply with quote
[quote="stu_gsxr"]sounds like throttle sticking
/quote]
what exactly is throttle sticking? as i mentioned earlier in the thread, i have about 1/8th of a turn play in the throttle cos the wire is loose. could this cause revs?
and wont air leak cos it to run rich? and not lean?
DM
PostPosted: 20:15 - 31 Jul 2005    Post subject: Reply with quote
It's a leak in the sense that extra air is being sucked in, not blown out.
Anyhow, a sticky throttle means literally that your throttle sticks when it's released. The cable is obstructed somehow, holding the engine at higher rpms. If your cable is frayed at either end then the threads can jam up inside the cable casing, preventing proper smooth travel.
stu_m
PostPosted: 21:01 - 31 Jul 2005    Post subject: Reply with quote
try oiling the cable
the inner cable maybe sticking inside the outer cable
The last post was made 21 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 61.87 Kb
