| veeeffarr |
 veeeffarr Super Spammer
| map |
 map Mr Calendar
 Posted: 14:57 - 09 Aug 2005 Post subject: |
Not a lot of info to go on but here's some thoughts...
The CG125 isn't the most modern of kit and has been around long enough not to have any major inherent flaws, so...
Is clutch cable running freely? Any snags? Check bite point. Could lube to make sure.
Assuming bike new to you then recent oil change? If so did you use synthetic or semi-synth? Could find the older engine design of the CG prefers semi-synthetic oil. If no oil change then I'd do it for peace of mind.
If the crunching is when you select first then...
Any damage to the selector pedal / linkage?
Are you trying to select first with high revs?
...although would expect more of a graunching (is that a word?) sound
...sorry if this doesn't help, just some ideas that I would check first. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| veeeffarr |
| Thedan |
 Thedan Derestricted Danger
| map |
 map Mr Calendar
| Josh|RD125LC |
 Josh|RD125LC World Chat Champion
 Posted: 23:25 - 09 Aug 2005 Post subject: |
My Honda 50 does exactly the same mate. When letting the clutch out slowly, or just sitting on a hill and letting it out a bit to act as a brake, it does 'crunch' sometimes, but I think 'clunk' is more of a better description for the noise. Is it a 'clunk' or 'crunch'? ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
| jimster |
 jimster Spanner Monkey
 Posted: 00:21 - 10 Aug 2005 Post subject: |
Maybe the clutch is a bit worn? Make sure you warm the bike up before using it, and if you want it to last better, don't do high-rev starts...!
PS I'd also change the oil, unless you know for sure when it was last changed. And don't use semi-synth oil (apparently it causes clutch slip) ____________________ Current: Yamaha Diversion XJ900
Previous: Yamaha Diversion 600cc, Piaggio Zip 50cc, Honda CG125-W, Siamoto Caddy 50cc moped |
| map |
 map Mr Calendar
 Posted: 00:28 - 10 Aug 2005 Post subject: |
| jimster |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 02:31 - 10 Aug 2005 Post subject: |
I've been running mine on 60p a litre oil with nothing obviously wrong. It hasn't complained at all.
Alternatively Castrol GTX 10W40 (not magnatech) will do the job just fine. ____________________ I must not be a troll...
Mmmm, Guinness
The last post was made 20 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
