Changing Gear
veeeffarr
PostPosted: 13:58 - 09 Aug 2005    Post subject: Changing Gear Reply with quote
Hi, I have a 2001 CG125 and I notice sometimes when letting the clutch out in first I sometimes get a horrible crunching noise which goes if I pull in and let the clutch out again... Only done 300 miles on it since I got it at 3800 miles, haven't fucked it up have i?
Cheers,
Toby
map
Mr Calendar
PostPosted: 14:57 - 09 Aug 2005    Post subject: Reply with quote
Not a lot of info to go on but here's some thoughts...
The CG125 isn't the most modern of kit and has been around long enough not to have any major inherent flaws, so...
Arrow Is clutch cable running freely? Any snags? Check bite point. Could lube to make sure.
Arrow Assuming bike new to you then recent oil change? If so did you use synthetic or semi-synth? Could find the older engine design of the CG prefers semi-synthetic oil. If no oil change then I'd do it for peace of mind.
If the crunching is when you select first then...
Arrow Any damage to the selector pedal / linkage?
Arrow Are you trying to select first with high revs?
...although would expect more of a graunching (is that a word?) sound
...sorry if this doesn't help, just some ideas that I would check first.
veeeffarr
PostPosted: 15:05 - 09 Aug 2005    Post subject: Reply with quote
Hi,
I think it's because I try and rev too high, because it's when I am trying to pull of quite quickly that it occurs.
I havent changed the oil yet, it was done before I bought it.
Cheers,
Toby
Thedan
PostPosted: 15:09 - 09 Aug 2005    Post subject: Reply with quote
I have a honda cg125 2000 model and i also get this i thought i might have broken it aswell. I have also only had the bike for a while it was on 2506 miles when i got it and have since done only 200 miles.
When the bike has been left for a while half a day or over night when i start the bike in the morning and select first gear the bike clunks/clicks and then goes forward on the suspension quite violent.
I have changed the oil recently with semi synth.
Many Thanks
Dan
map
Mr Calendar
PostPosted: 15:47 - 09 Aug 2005    Post subject: Reply with quote
Some info from my head and that of others...
Thedan wrote:
...when i start the bike in the morning and select first gear the bike clunks/clicks...
That'd be the clutch plates sticking together and not completely releasing when you pull in the clutch. The oil between the clutch plates transmits a little motion which means the input shaft can be turning slightly. So you get a clunk (and maybe forward motion if turning a bit more). Normal for many motorcycles, especially on startup when the oil is doing funny things. May be worse at low temperature as oil will be thicker. Could try fully synth oil as this thinner over greater temperture range. However, fully synthetic could cause problems with the clutch, either slippage or greater wear.
Try working the clutch lever a few times before moving off, and then select first, as this might help minimise it.
I shouldn't worry about it, just ride Very Happy.
Josh|RD125LC
PostPosted: 23:25 - 09 Aug 2005    Post subject: Reply with quote
My Honda 50 does exactly the same mate. When letting the clutch out slowly, or just sitting on a hill and letting it out a bit to act as a brake, it does 'crunch' sometimes, but I think 'clunk' is more of a better description for the noise. Is it a 'clunk' or 'crunch'?
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
jimster
PostPosted: 00:21 - 10 Aug 2005    Post subject: Reply with quote
Maybe the clutch is a bit worn? Make sure you warm the bike up before using it, and if you want it to last better, don't do high-rev starts...! Rolling Eyes
PS I'd also change the oil, unless you know for sure when it was last changed. And don't use semi-synth oil (apparently it causes clutch slip)
Current: Yamaha Diversion XJ900
Previous: Yamaha Diversion 600cc, Piaggio Zip 50cc, Honda CG125-W, Siamoto Caddy 50cc moped
map
Mr Calendar
PostPosted: 00:28 - 10 Aug 2005    Post subject: Reply with quote
jimster wrote:
...don't use semi-synth oil (apparently it causes clutch slip)
Read my post above. Full synthetic oil is most likely to cause clutch slip. This is mainly due to the additives that, well, make it slippier Wink. The other arguement is that if it doesn't do that then because it's slippier there's less of it between the plates and therefore they'll wear out quicker.
Full synth oil is ok on bikes designed to run on the stuff, engines, clutch etc. made to the job and tested to perform with the oil. Older, and less powerful machinery is okay with the semi-synth. You'd have to be an enthusiast to know where to put mineral oil (even that's not mineral oil anymore).
HTH Thumbs Up
jimster
PostPosted: 00:54 - 10 Aug 2005    Post subject: Reply with quote
I did read your post - Rolling Eyes I think that as 125 bike engines were designed to be used with mineral oil, mineral oil will be just fine.
But I'm just parroting back what other people have said, so it's a bit pointless arguing about it Smile
mchaggis
PostPosted: 02:31 - 10 Aug 2005    Post subject: Reply with quote
I've been running mine on 60p a litre oil with nothing obviously wrong. It hasn't complained at all. Laughing
Alternatively Castrol GTX 10W40 (not magnatech) will do the job just fine.
I must not be a troll...
Mmmm, Guinness
The last post was made 20 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 69.55 Kb
