Sola Larm
Kram
PostPosted: 01:13 - 10 Aug 2005    Post subject: Sola Larm Reply with quote
... sometimes.
i have had nothing wrong with this alarm, until today...
i went out for a 45 mile trot around the countryside (no electrics on, so battery is charging)... got home, turned my biek off and the alarm armed.
went to check the voltage of the bike (lights were glowing last night). Shot i can't turn my alarm off. (none of my key fob things worked). so i stuck with the alarm sounding until i could get to the battery, and checked the voltage... 12.9Volts, batteries charged.
phoned up the place that installed my alarm(which i've had since february) and they said "it's probably a flat battery" so i told them it was fully charged, and they said to take the bike up to there shop (3 miles away) and they will reset it...
how do you transport a bike, that has the alarm stuck on... that will go off on touch/tilt/ignition?... i told them this and they said they would send the mechanic out tomoro morning...
i hate G.R.sportsbikes, sometimes
Drummer
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
benc
PostPosted: 02:02 - 10 Aug 2005    Post subject: Reply with quote
find the alarm and cut one of the cables that goes 2 it at a decent length and re connect later?
sickpup
Old Timer
PostPosted: 02:03 - 10 Aug 2005    Post subject: Reply with quote
Gaffer tape a rag over the siren.
Kram
PostPosted: 02:04 - 10 Aug 2005    Post subject: Reply with quote
alarm is bolted to the plastic... all the cables are black, and fork me, if i can find the right cable (also has internal backup battery power)
Flip
PostPosted: 02:10 - 10 Aug 2005    Post subject: Reply with quote
Does the alarm have a sleep mode?
I thought that's what they were for?
EDIT/ Just read that your fobs are f*cked.
Ducati750s
PostPosted: 09:45 - 10 Aug 2005    Post subject: Reply with quote
Your complaining about the bike shop? Now I don't know anything about them, but what more can they do other than deliver a mechanic to YOUR door, the very next morning after you have rang up???
Some people are never happy!! I bet you won't even make him a cup of tea!
Kram
PostPosted: 10:03 - 10 Aug 2005    Post subject: Reply with quote
i phoned up the bike shop at lunchtime (while it was open) it's not just the alarm that made me disike the bike shop! it was the 1 and a half week delay on getting my bike, then me taking it back 2 days later with a ruptured fuel line, then back again a week later for something else.
map
Mr Calendar
PostPosted: 10:15 - 10 Aug 2005    Post subject: Re: Sola Larm Reply with quote
Drummer wrote:
...none of my key fob things worked...phoned up the place that installed my alarm(which i've had since february) and they said "it's probably a flat battery"....
Just to check, sure they didn't mean a flat battery in the fob(s). Not sure how long they'd have been in stock before you started using it.
Just an idea Thumbs Up
Kram
PostPosted: 10:42 - 10 Aug 2005    Post subject: Reply with quote
just got of the phone, and they told me how to fix it...
have to disconnect the battery turn the ignition, it's all good fun.
just checked my battery... no fluid in it Shocked. looks like i'm after a new Reg/Rec Crying or Very sad
R4nger
PostPosted: 14:56 - 10 Aug 2005    Post subject: Reply with quote
Refill the battery with fluid first because otherwise it will not hold charge. The fulid usually gets empty though from recharging lots.
Kram
PostPosted: 23:57 - 10 Aug 2005    Post subject: Reply with quote
i filled the battery with ionised water, but am buying a new batteyr (hopefully tomoro) if i get my money. then will charge it and stick it in
dransy
PostPosted: 00:09 - 11 Aug 2005    Post subject: Reply with quote
Hey that happend to me
what you have to do is unscrew the black box with the speaker from the wires , get one of them pens that lights up if there is power going threw , and when you unscrew the box youll see the big thick wire that you unscrewed has like 10 little squares , stick the pen in there and find the faults , there will be 2 faults , you get a little piece of wire and put it in 1 to the other this will bypass it .
hope it helps , maybe abit confusing.
Kram
PostPosted: 00:11 - 11 Aug 2005    Post subject: Reply with quote
is fixed now, i had to reset the codes so the key fobs work.
PM me if you want the instructions (only for the model i got though - not sure what one it is)
dransy
PostPosted: 00:13 - 11 Aug 2005    Post subject: Reply with quote
Ah nice 1 , it rained and water got in mine and the imobalisor stopped working at a petrol station ha! Sad
then the sound went so i sent it off to sola-larm they fixed it sent me it back left it outside and it rained again , and then the sound went again , left it a few days it dried out , sound is back but now it goes off on its own once ive armed it , also the lights have stopped flashing when you arm dissarm it.
In my opinion i wouldnt recomend these alarms
Kram
PostPosted: 00:15 - 11 Aug 2005    Post subject: Reply with quote
mine has got slightly wet, but works.
the indicators don't flash if you have a low/dead battery though. i personally find it ok as an alarm... unless you are working on the engine and constantly arm/disarming it because the immobiliser kicks in every 30 seconds :@
no_shad
PostPosted: 00:27 - 11 Aug 2005    Post subject: Reply with quote
I remember seeing them in a mag or catalogue or something.
Although they are a good idea, I remember them being stupidly expensive.
Kram
PostPosted: 00:29 - 11 Aug 2005    Post subject: Reply with quote
£150 odd quid plus installation (professional only)
got mine ree with the bike though
The last post was made 21 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 2.41 - MySQL Queries: 13 - Page Size: 94.83 Kb
