Diffrences 600 1000???
A J
PostPosted: 21:40 - 11 Aug 2005    Post subject: Diffrences 600 1000??? Reply with quote
I just want know how much real power diffrence there is between the 600 sports and the litre sports.
I know the statistics but are they really that much faster and powerfull that you have to be extremly carefull when opening the throttle etc?
Would you be a quicker rider if you swapped your 600 for a thou or would it not make much diffrence?
This is not for me thinking that if i got a thou i would be valintino just when i see bike reviews they always say that you have to be so carefull on them etc.
Twisted Evil Twisted Evil
Dom_
Points Mean Prizes
PostPosted: 21:45 - 11 Aug 2005    Post subject: Reply with quote
Yes there is a huge difference.
If anything your riding skill would de-crease if you swapped for a thou, you'd become a lazier rider.
craigie b
Citizen Smith
PostPosted: 21:52 - 11 Aug 2005    Post subject: Reply with quote
Why?
dransy
PostPosted: 21:55 - 11 Aug 2005    Post subject: Reply with quote
Because you have so much power and have to do nothing to get it Razz its just there instantly in 1 big lump
dibbster
PostPosted: 22:11 - 11 Aug 2005    Post subject: Reply with quote
As an example the R6 is around 100bhp and 170kg (dry).
The R1 is around 180bhp and 180kg (dry)*
They are essentially the same weight but the R1 has around 80% more power. Thou's will reach 60 in the blink of an eye and go on to 100+ in first and thats why you need to be careful with them!
*These are just rough figures.
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
cc123
Geez a joab?
PostPosted: 22:32 - 11 Aug 2005    Post subject: Reply with quote
There wouldn't be much in the 0-60 time, maybe the 0-100 time but only after then would you see huge difference in accelerations times.
I had a go on an old R1 off the back of my Ninja600 and thought fcuk! Shocked
Wouldn't make you any better though, after 2 weeks ago seeing 125's to 1400's keep within the same time and speeds almost, through miles of country B-roads. All depends on how much your willing to push.. Confused
There's only so fast you can go before your having to slow again.
Old bikes >>> https://www.bikepics.com/members/cc123/
johnsilva
PostPosted: 23:41 - 11 Aug 2005    Post subject: Reply with quote
Flipping Heck! That is a VERY rough figure matey!
An R6 makes 100bhp @ wheel and weighs 163kg dry
R1 makes 148bhp @ wheel and weighs 174 dry
but all 600 and 1000 cc bikes weigh the same wet, about 200kg. So weight really is not an issue.
Power is only a matter when you are talking about top speed, 600's will all crack 160mph and the 1000's are all restricted to 186mph.
What you really should look at are torque curves and the spread of the torque over a range of revs, after all, power is only Torque multiplied by revs.
With regards to how much different it would feel, if you look at the thrust (torque multiplied by gear ratio) curves of a 600 and 1000, you would see that they make about the same amount of thrust in 1st gear, about 700lb. So they will feel as fast as each other, to a point.
Thing is, a 600 only does about 60mph ish in 1st gear, whereas a 1000, will hit 100mph in first gear.
I hope this helps
John
Current Bikes: ZX7R P5; KR1S C2; GPX250R F3
Previously: CBR400RR-R; YQ50 Aerox
dibbster
PostPosted: 23:52 - 11 Aug 2005    Post subject: Reply with quote
From Yamaha's website
Maximum power With direct air induction: 132kW (180 HP) @ 12,500rpm
craigs23
Mr Muscle
PostPosted: 23:56 - 11 Aug 2005    Post subject: Reply with quote
Hate to butt in here, but that's Yamaha's claimed power figure at the crank, not the rear wheel. The same site says that the R6 makes 92.7kW (126 HP) @ 13,000rpm.
EllioTT_GiXXeR
PostPosted: 00:04 - 12 Aug 2005    Post subject: Reply with quote
If you want a 1000, get a V-Twin, sound the best.
Big difference in the power tho.
Silver
PostPosted: 00:07 - 12 Aug 2005    Post subject: Reply with quote
Figures don't tell the whole story; I went from a 100bhp ZX6R to a 125bhp GSXR750 and the difference in grunt and speed is awesome.
CoronaBoner
PostPosted: 00:27 - 12 Aug 2005    Post subject: Reply with quote
Interesting subject. I have wondered too what differences a 600 to a thou would be. Although im more than happy with my 600.
Why is it that they are restricted to 186mph though? I knew the Busa had this but didn't know others did too.
Would love to try a thou though, I got a quote on a RSVR .. £3000 fire and theft only Smile 19/garaged/2-3 years NCB.
thats when dreams don't come true.
Embarassed
2004 RSV Factory
Cluck cluck chicken
Gracie Jones
PostPosted: 00:34 - 12 Aug 2005    Post subject: Reply with quote
He said he knew the stats, so we start on about stats!!
Basically, a litre bike will wheely off the throttle in many gears, probably up to 3rd. You will be able to make the wheels spin changing gear and you will also be liable to make the rear wheel spin quite easily coming out of corners, giving possibility of high-side.
A really top 600 will do similar, but most 600s will not. e.g. my 98' model ZX6R won't do any of the above - although having said that I am not a particularly hard rider.
Gazdaman
I did a trackday!!!
PostPosted: 01:22 - 12 Aug 2005    Post subject: Reply with quote
I've never ridden a litre bike.
But I've ridden an R6 and a VFR800, the VFR was quite noticably quicker, the front came up in third without even thinking twice.
I've not ridden either bike hard enough to know about any of the other wheel slidey side of things.
Gaz
dodsi
Dirty Carny
PostPosted: 01:35 - 12 Aug 2005    Post subject: Reply with quote
After riding the ER-5 the onto a bandit the bandit felt fast.
Had a go on Black knights VFR750 (after being bullied into it and threatend with beatings if I didnt) as I did decline the offer straight away!
The VFR felt amazing. Its like riding in the powerband of a 600 in any gear all the time.
The torque of the bigger bikes is the cool thing. you can burble along at 30mph in third, blip the throttle and the bike just takes off the same as your 600 would if you got it into the sweet spot.
But then it just gets faster and faster.
also its smooth too, you dont realise as its so easy to get well above 100. I had the VFR above 100 the first time I rode it really quickly.
600's are fast...bigger bikes are imense.
Zen Dog
PostPosted: 10:17 - 12 Aug 2005    Post subject: Reply with quote
The VFR750, 3 appropriate gears for any situation... Mr. Green Thumbs Up
Gracie Jones
PostPosted: 12:35 - 12 Aug 2005    Post subject: Reply with quote
VivaCity - you really are a total nob jockey aren't you? A million apologies for flaming / thread-jacking, whatever . . .
How was my post remotely off-topic?
Ever since I pointed out that you are an unreconstructed racist all those months ago, you have negatively rated a number of my posts.
Stop being such a small minded prick. You are hiding your anger behind giving people poor ratings, which I also see you give the gay-boys because their threads are 'boring'.
If you want to say something, say it out in the open. Stop being such a coward.
ZZRman
PostPosted: 22:46 - 12 Aug 2005    Post subject: Re: Diffrences 600 1000??? Reply with quote
A) ever riden a 400cc bike... well you have 400cc more if you go for a 1000cc, I ride a 1100 with about 138~145 bhp, its not slow, rode my inlaws R6 mmm, now without been rude I didnt see the point of why they made a 600, I feel you had to rev the poor bugger to get anywhere, on my bike open it up and you're 100mph in just under 4 seconds, that should tell you something
A) Yes, very much faster, my bike is capable of easily doing 180+, I've taken it to 170 and I need to get home fast after that...(done it abroad) its not always about speed, in bends a smaller bike like a R6 will flick through where as I'll need to work it through.
A) Speed yes, bends no, depends on weight and design of bike (Sports bikes)
A) Big bikes can create a sense of over confidence if doing the speed thing, todays 600 arnt slow by no means but more that they lack power
Opinions will vary, these are just my own findings
tooldaddy
PostPosted: 18:10 - 13 Aug 2005    Post subject: 600_1000 Reply with quote
i have been reading all the responces to your question with much merryment .
at the end of febuary last year i traded my 99 r6 in for the 04 r1 .
i have had the r6 for 2 years and have done track days and raced arround the local mountain roads . then when i got the r1 i had to re learn how to ride a bike . as they are chalk and cheese .
its like comparing a lada with binding brakes to a ferrari .
and you need arms of steel to steer with as they dont like to turn when ridden hard .
you also have to factor in the extra running costs , ie , tyres , fuel , brakes , insurance , chains , tyres . underpants .
richard.1975@btinternet.com
Bendy
Mrs Sensible
PostPosted: 00:13 - 15 Aug 2005    Post subject: Reply with quote
I'd say the R6 really wasn't very well that day, as it had less 'go' on the straights than my bog standard CBR6 roadbike.
PostPosted: 00:18 - 15 Aug 2005    Post subject: Reply with quote
Two main things with a thou:
The decent acceleration carries on further, meaning you can accelerate at 90 as hard as you can at 50 on the 600. In a similar fashion it continues to accelerate well enough into double figures where the 600 bogs down a bit.
Low down power; 600s are still relatively fast low down, but when compared to a 1000 they feel quite gutless; down gear a 1000 and you'll get decent acceleration in top gear at lows revs still. Whatever, you'll have a much broader range of torque, so less gear changing is needed to get the same effect.
Erk, it comes up off the power in second if you get it right normally.
Third can probably be clutched up.
Did a small wheely down the short straight (below the padock) at brands and it ended up lasting 2/3rds of the straight (had to put it down as there was orange people waving red flags infront of me!)
MarkyPancake
PostPosted: 12:20 - 15 Aug 2005    Post subject: Reply with quote
I had a J2 and rode a friend's K4 750 and the difference was very noticeable, from the riding position to the power and handling, it felt like a completely different league of bike.
I went from my J2 to an 04 R1, the same model and colour as tooldaddy's, but with a few cosmetic tweaks, and the jump wasn't what I expected.
I thought I'd be wheelying by accident and struggling to hang on, but the power delivery is smooth and I have found it easier to ride and it handles better than my old J2. So far no wheelies.
Don't get me wrong it's quick, but not what I expected and from what I've read and can tell the 04 R1 lacks low end torque. The power is in the higher revs, but by the time you're up there you have already been banned!
What I have noticed:
  • Uses more fuel
  • Don't need to use as many gears (I do to increase fuel economy)
  • Rear wheel spins up much easier both downshifting and upshifting
  • Corners better
  • Handles high speed better (might be more the aerodynamics of the bike)
  • Without much effort you're breaking the speed limits
That said I'm not heavy handed with the throttle on any bike and don't really ride fast. You could say it's a waste of the bike really.
kaillum
PostPosted: 12:03 - 16 Aug 2005    Post subject: Reply with quote
i had a CBR600.. and recently moved up to an RSV Factory...
The CBR felt quick.. Would pull up in 1st & 2nd with a quick crack of the throttle... The RSV on the other hand will pull up in 1st & 2nd without a crack of the throttle..
I test rode an R1 before buying the RSV.. and at 100mph in 3rd.. crack the throttle and the front wheel points at the sky.. Scarily quick!
Where the 600's 'feel' quick.. the 1000's ARE quick.. similar 0-60 times.. (well. all less than 4 secs!) but the 1000's just keep pulling.. and pulling.. and pulling.. and pulling.. and then you change gear and it happens all over again!
Walloper
PostPosted: 12:12 - 16 Aug 2005    Post subject: Reply with quote
You make a good point there but I can't buy that.
I went from a 600 T/cat effing great bike to a 955 Sprint ST.
Roughly the same style of bikes but a wanking great difference in power. I couldn't be happy on a 600 now. I'm a convert.
You need more skill on bigger bike not less.
Insurance companies are not sold on your theory either it would appear.
W
Dom_
Points Mean Prizes
PostPosted: 14:08 - 16 Aug 2005    Post subject: Reply with quote
You mis-understand me. I don't mean lazier as in slower, i mean lazier!
With the smaller cc bikes you need to go through the 'box to keep the revs high where all the power is. With a big bike, where you'd drop a couple of cogs on a smaller bike, you'd probably just give a fist full of throttle on a 1000cc or similar and it would have enough torque to pull you out of the corner sharpish.
Obviously i worded what i said wrong, i didn't mean to say skill would de-crease. But you would become less bothered about getting every last ounce of hp coming out of a corner, simply because theres so much already.
Don't confuse what i just said with becoming a slower rider though, obviously you can still hit stupid speeds and go round the twisties/track at a good pace, but you'd need to work a lot less than someone riding a 600 would.
Insurance companies insure on claims/hp/area/background - millions of different things, not theorys.
As for needing more skill on a bigger bike, thats questionable. I have first hand experience, i was on the back of a mates 18 year old cbr 400, on the way back to the cat and fiddle from matlock, we actually went around the outside of a rsvr factory and he never caught up with us. The exact same can be said for a crap rider on a 400 and a good rider on a 1000, but the principle remains, you don't need to have more skill to ride a big bike. You need more skill if you want to ride a big bike fast. Wink Mr. Green
The last post was made 20 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 136.2 Kb
