RC valves - Dont get it
DimmniBurek
PostPosted: 19:04 - 11 Aug 2005    Post subject: RC valves - Dont get it Reply with quote
Hi, I am searching here for some info about this RC valve, but I still dont know what and ehere it is, I own a NSR 99ยด. My friend send mw this picture, bu t he didnt knew where can I find this valve, can anybody post the real picture of this on NSR?
https://www.bikechatforums.com/download.php?id=19497
Sorry for bad english
There Is No Stronger Drug Than Reality
There Is No Engine Like TURBO Engine
cagiva gezzer
PostPosted: 19:43 - 11 Aug 2005    Post subject: Reply with quote
different engine, but should be the same place.
DimmniBurek
PostPosted: 19:54 - 11 Aug 2005    Post subject: Reply with quote
Aha, I know where it is, now, can you tell me what does it do?
And how should I adjust it?
mr jamez
PostPosted: 20:07 - 11 Aug 2005    Post subject: Reply with quote
It is a valve that sits in the barrel just after the exhaust port, at low revs it is closed making the bike a little more rideable, then at around 7krpm it opens up and you get full powah! (very simplified explanation)
The manual will tell you everything you need to know about adjusting it.
DimmniBurek
PostPosted: 21:11 - 11 Aug 2005    Post subject: Reply with quote
OK, but what is this picture in first post? Do i have to mold that cover off or what?
This is RAVE valve which aprilias have, right?
mr jamez
PostPosted: 21:16 - 11 Aug 2005    Post subject: Reply with quote
Yep undo the two bolts and remove the cover, then use the adjusting nut on the left hand cable. You HAVE to use the manual to get it properly setup.
DimmniBurek
PostPosted: 09:28 - 12 Aug 2005    Post subject: Reply with quote
I am almost 100% that in the manual does not write anything about setup, what about the picture in first post? This is for NSR as I know
hproduction
PostPosted: 12:42 - 12 Aug 2005    Post subject: Reply with quote
NSR 125 R 99. Been reading some replies from you and I need help. I need to know where the powervalves is/are so I can clean them. Also my Servo, i'm not sure how it works but it's always on Low. When I "Key-on" it twitches but remains on Low. Rev up to 6500 and over it still remains on Low. Is this right?? I need your help.
I believe it could be something to do with the CDI maybe?
Thanks
mr jamez
PostPosted: 12:53 - 12 Aug 2005    Post subject: Reply with quote
It IS in the manual, I have adjusted it using that more times than I can remember. Have a search on the forums or google and download it.
First remove the exhaust. Then remove the RC valve cover, cables and the pulley which is held on by a left hand thread nut so turn it the opposite way to undo. Two more bolts to get the plate off the barrel. remove the RC valve dust seal then pull out the spindle. Remove the RC valves from the barrel.
Sounds like you need to adjust the timing of the valves for them to work correctly. If they don't work after that then there could be a loose connection, problem with the power valve actuator or servo.
hproduction
PostPosted: 13:00 - 12 Aug 2005    Post subject: Thanks Reply with quote
Thanks a lot Mr. James! I will try it today.
Also, how is the Servo Motor suppose to react? I can't really understand that diagram.
Please let me know. Thanks
Visit www.hustlerproduction.tk for ?1 albums!
DimmniBurek
PostPosted: 13:43 - 12 Aug 2005    Post subject: Reply with quote
What is this on the picture? When I start the bike it moves, and when ~6500 rpm is reached too
https://www.mobisux.com/album/data/500/32930IMG_9062-med.jpg
This is under the fuel tank
hproduction
PostPosted: 13:52 - 12 Aug 2005    Post subject: Reply with quote
Thats the Servo motor my friend, A diagram is at the top of the page. Look closely ad there should be a pointer and High or Low markings. Please tell me when you tun the key. Where is it pointing and does it just twich or move completely? Also when you go above 6500 how does it move and where is it pointing?
This would really help me as mine might be broken. Thanks
DimmniBurek
PostPosted: 14:53 - 12 Aug 2005    Post subject: Reply with quote
Your friend will give you info soon...
So this servo controls the RC valve?
Do I have to setup both or just the servo?
The bike runs properly, but my friend told me that this is like a restrictor, and the bike runs better if this is set properly?!?
PostPosted: 15:05 - 12 Aug 2005    Post subject: Reply with quote
You do not adjust the servo, just the cables that connect the servo to the valve.
It is not a restrictor (although I understand that some French market bikes are restricted by closing the valve at high speed, but you cannot stop this by adjusting it), but needs to be set up to give you full power at high revs (if it does not open fully then you will not get full power, just as if it does not close fully you will loose some power at low revs).
I would not like to try removing the RC valve from the engine with the engine in place. It is fiddling to do with the top of the engine taken off the bike. Not sure that they stick very often anyway.
RAVE is the Aprilia / Rotax power valve system. These are a simple and light system, but are prone to sticking (but can easily be removed and cleaned up with much work compared to the NSR).
yaut
PostPosted: 12:53 - 27 Dec 2005    Post subject: Reply with quote
My nsr refuses to rev above 7500revs in 5th/6th.
I've taken the exhaust off my nsr and this is what I see through its port.
Q#1: is this the way rc valve should sit in there?
Q#2: is it possible to operate it by hand? just to check if it's working properly?
all dogs go to heaven
The last post was made 20 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 87.06 Kb
