| MZ125 |
 MZ125 Nova Slayer
| dransy |
 dransy World Chat Champion
| MZ125 |
 MZ125 Nova Slayer
| Kickstart |
 Kickstart The Oracle
 Posted: 18:31 - 12 Aug 2005 Post subject: |
Rear caliper on a Bandit? They are well known for seizing in place.
Order some new pins first (hopefully the dealer will keep them in stock).
When I had this problem one suggestion was to drill a small hole in the caliper on the side the pin goes into (one side the hole goes through, the other side it is blind) and then try and use a punch through the hole to drive the pins out. That didn't work.
More success was with using a Dremel to cut a section out of each of the pins so that each was only seized in place at one point.
| MZ125 |
 MZ125 Nova Slayer
| Kickstart |
| PsychoHippy |
 PsychoHippy Jammy Git
 Posted: 23:26 - 12 Aug 2005 Post subject: |
Totally agree with Keith on this - the pins on my 1200 Bandit were a complete arse to get out every time. Ended up doing exactly what Keith said, cut them in half and then they are easier to get out.  ____________________ I spend all my money on bikes and beer, the rest I simply waste! |
| MZ125 |
 MZ125 Nova Slayer
| MZ125 |
 MZ125 Nova Slayer
| MZ125 |
 MZ125 Nova Slayer
| Liono |
 Liono Spanner Monkey
 Posted: 09:44 - 13 Aug 2005 Post subject: |
If (as I think they are) the pad pins on Bandit calipers are the same as those on the SV there is a bloke on an SV forum making stainless ones which should be less prone to seizure. I intend to buy some soon. After my pins managed to get themselves extremely well stuck in place I now make sure they are well covered in copper slip, and each time I give the bike a clean I try to make sure I rotate them a little bit, just to keep them moving. The link for the post is:
https://forums.sv650.org/viewtopic.php?t=17847&postdays=0&postorder=asc&highlight=stainless&start=0
Just realised it is a couple of months old now, but perhaps if you ask he might still be doing them.
If you wanted to, someone posted an idea for a way to make your own version of stainless pins here:
https://forums.sv650.org/viewtopic.php?t=21001&highlight=stainless |
The last post was made 21 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
