NEED HELP WITH BRAKES
MZ125
PostPosted: 18:05 - 12 Aug 2005    Post subject: NEED HELP WITH BRAKES Reply with quote
Iam trying 2 take out the rear brake pads out but the pins dont seem 2 want 2 budge has any 1 got any ideas how 2 budge them cheers 4 any help
bandit 600 honest i dont brake the speedlimit I just dont stick 2 it
dransy
PostPosted: 18:06 - 12 Aug 2005    Post subject: Reply with quote
Have you tried using pliars? maybe a lil bit of good old wd40 might help abit?
MZ125
PostPosted: 18:12 - 12 Aug 2005    Post subject: Reply with quote
yep tryed that they just arnt budging
PostPosted: 18:31 - 12 Aug 2005    Post subject: Reply with quote
Rear caliper on a Bandit? They are well known for seizing in place.
Order some new pins first (hopefully the dealer will keep them in stock).
When I had this problem one suggestion was to drill a small hole in the caliper on the side the pin goes into (one side the hole goes through, the other side it is blind) and then try and use a punch through the hole to drive the pins out. That didn't work.
More success was with using a Dremel to cut a section out of each of the pins so that each was only seized in place at one point.
MZ125
PostPosted: 18:45 - 12 Aug 2005    Post subject: Reply with quote
cheers is there any way drilling throu the other side and popping it out throu that side
i have got 2 calipers
cheers 4 your help guys
PostPosted: 21:29 - 12 Aug 2005    Post subject: Reply with quote
You can try drilling a small hole. Afraid that did not work for me. They are pigs.
PsychoHippy
Jammy Git
PostPosted: 23:26 - 12 Aug 2005    Post subject: Reply with quote
Totally agree with Keith on this - the pins on my 1200 Bandit were a complete arse to get out every time. Ended up doing exactly what Keith said, cut them in half and then they are easier to get out. Thumbs Up
I spend all my money on bikes and beer, the rest I simply waste!
MZ125
PostPosted: 00:04 - 13 Aug 2005    Post subject: Reply with quote
hi i have got 1 caliper done from drilling from the opposit side & whacking the pins out just means i will need 2 do it again & bleed the thing again cheers 4 your help guys if only suzuki made things easy
MZ125
hi i have got 1 caliper done from drilling from the opisit side & whacking the pins out just means i will need 2 do it again & bleed the thing again cheers 4 your help guys if only suzuki made things easy
MZ125
Liono
PostPosted: 09:44 - 13 Aug 2005    Post subject: Reply with quote
If (as I think they are) the pad pins on Bandit calipers are the same as those on the SV there is a bloke on an SV forum making stainless ones which should be less prone to seizure. I intend to buy some soon. After my pins managed to get themselves extremely well stuck in place I now make sure they are well covered in copper slip, and each time I give the bike a clean I try to make sure I rotate them a little bit, just to keep them moving. The link for the post is:
https://forums.sv650.org/viewtopic.php?t=17847&postdays=0&postorder=asc&highlight=stainless&start=0
Just realised it is a couple of months old now, but perhaps if you ask he might still be doing them.
If you wanted to, someone posted an idea for a way to make your own version of stainless pins here:
https://forums.sv650.org/viewtopic.php?t=21001&highlight=stainless
The last post was made 21 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 69.45 Kb
