| OreoXX |
 OreoXX Nova Slayer
 Posted: 11:45 - 17 Aug 2005 Post subject: Re-Jetting |
I have spent hours reading through the forum trying to find out which jets i should use for my NSR, but everyone seem to be saying something different.
So my NSR is a French import 2001 NSR Supersprint, and I have fitted a Gianelli Exhaust and removed the carb/inlet restrictor. I have heard that you need to change 3 different jets, is this true? If it is, could someone tell me the names and sizes of the different jets that need to be replaced??
Thanks  |
| Kickstart |
 Kickstart The Oracle
 Posted: 11:52 - 17 Aug 2005 Post subject: |
3 "jets" you need to play with are the main jet (which you substitute with a larger one), the needle jet (which is available with lots of different profiles, but which you normally can just move the locating clip to richen / lean the mixture a touch) and the idle mixture screw / idle air screw (which you can just turn to adjust it).
Probably just go up 1~2 sizes on the main jet and see how that goes, and lift the needle up slightly (move the clip on the needle down to the next notch, towards the point).
| OreoXX |
 OreoXX Nova Slayer
| Kickstart |
| airpig |
 airpig Scooby Slapper
| DimmniBurek |
 DimmniBurek Renault 5 Driver
| alains |
 alains World Chat Champion
 Posted: 17:21 - 14 Dec 2005 Post subject: |
the genuine jets are : main 132 , slow 38 , power 55
i recommand : main 138 , slow 42 , power 65
for the 160cc kit : main 150 , slow 45, power 70
no jets on needle as says one of you . order to mattew at dellorto : sales@dellorto.co.uk (around £3.2 each) ____________________ the worst day fishing is better than the best day working |
| DimmniBurek |
| Kickstart |
 Posted: 22:26 - 20 Dec 2005 Post subject: |
Normally the restriction is just dropping the power valve, and no rejetting is needed. However if it is a cat exhaust that has been gutted then it might need some playing with.
It is basically the same carb as the NSR, Dellorto PHBH28, but there are differences.
Looking at my RS manual it mentions a 115 main jet for the catalised version. Older AF1 manual uses basically the same engine with a 125 main jet, but the needle on a leaner setting. I would go for a 120 main jet and have a play with the needle.
The last post was made 20 years, 48 days ago. Instead of replying here, would creating a new thread be more useful? |
