Re-Jetting
OreoXX
PostPosted: 11:45 - 17 Aug 2005    Post subject: Re-Jetting Reply with quote
I have spent hours reading through the forum trying to find out which jets i should use for my NSR, but everyone seem to be saying something different.
So my NSR is a French import 2001 NSR Supersprint, and I have fitted a Gianelli Exhaust and removed the carb/inlet restrictor. I have heard that you need to change 3 different jets, is this true? If it is, could someone tell me the names and sizes of the different jets that need to be replaced??
Thanks Wink
PostPosted: 11:52 - 17 Aug 2005    Post subject: Reply with quote
3 "jets" you need to play with are the main jet (which you substitute with a larger one), the needle jet (which is available with lots of different profiles, but which you normally can just move the locating clip to richen / lean the mixture a touch) and the idle mixture screw / idle air screw (which you can just turn to adjust it).
Probably just go up 1~2 sizes on the main jet and see how that goes, and lift the needle up slightly (move the clip on the needle down to the next notch, towards the point).
OreoXX
PostPosted: 11:56 - 17 Aug 2005    Post subject: Reply with quote
Ok, that helps a lot, thanks! I'm off to buy the 138 main jet now, and I will check how that works. But what does 138-42-65 mean then?
Thanks
PostPosted: 14:09 - 17 Aug 2005    Post subject: Reply with quote
Not sure what size is standard (thought it was about a 125). The jets are pretty cheap so I would buy a selection and have a play. Running too rich is fairly safe but will increase fuel consumption and foul plugs more quickly, but running lean can cause seizures or holed pistons. Therefore start rich and work down.
Not a clue!
airpig
PostPosted: 14:45 - 17 Aug 2005    Post subject: Reply with quote
Thanks
They're the sizes of your main, slow and power jets Smile
DimmniBurek
PostPosted: 16:59 - 14 Dec 2005    Post subject: Reply with quote
Hi, my friend has a 160ccm kit on a NSR, he needs bigger jets, which do you reccomend? Those for derestrcted would be too small i think?!?
There Is No Stronger Drug Than Reality
There Is No Engine Like TURBO Engine
alains
PostPosted: 17:21 - 14 Dec 2005    Post subject: Reply with quote
the genuine jets are : main 132 , slow 38 , power 55
i recommand : main 138 , slow 42 , power 65
for the 160cc kit : main 150 , slow 45, power 70
no jets on needle as says one of you . order to mattew at dellorto : sales@dellorto.co.uk (around £3.2 each)
DimmniBurek
PostPosted: 19:16 - 20 Dec 2005    Post subject: Reply with quote
What about for 2001 Aprilia RS 125? My friend has derestricted the exhaust and he needs bigger jets, main jet is 110 I think, but I am nopt sure if there is the same carb like in the Honda NSR 125!
PostPosted: 22:26 - 20 Dec 2005    Post subject: Reply with quote
Normally the restriction is just dropping the power valve, and no rejetting is needed. However if it is a cat exhaust that has been gutted then it might need some playing with.
It is basically the same carb as the NSR, Dellorto PHBH28, but there are differences.
Looking at my RS manual it mentions a 115 main jet for the catalised version. Older AF1 manual uses basically the same engine with a 125 main jet, but the needle on a leaner setting. I would go for a 120 main jet and have a play with the needle.
The last post was made 20 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 62.67 Kb
