CBR 600 F1 Bent Forks ???
Dinnaz
PostPosted: 23:15 - 17 Aug 2005    Post subject: CBR 600 F1 Bent Forks ??? Reply with quote
... heres the problem. When I put my Handle bars straight, and I stand at the front of the bike, my front wheel slighty goes off to my right.
I had noticed this before and thought that the front fender was bent, but is actually fine and is the wheel that makes it look bent.
However if I straighten the wheel, the forks and wheel are straight, yet the handle bars nd fender point slightly to the right.
Problem I have is the bike is still under warrinty, just. But I'm in Newcastle and the Dealer is in Stockton, and they want the bike in before 9.30 and will have it back for 4.00 pm. It's just that I don't fancy sitting around all day twiddling me thumbs.
My question is, is this easy to sort yer self, or if I take to a garage, any ideas how much they will charge???
mr jamez
PostPosted: 11:26 - 18 Aug 2005    Post subject: Reply with quote
If it is under warranty and they are willing to fix the bike then let them deal with it.
The forks might just be twisted in the yokes.
Big Pete
PostPosted: 12:03 - 18 Aug 2005    Post subject: Reply with quote
It sound like the forks are twisted in the yokes, if you want to do it yourself its not hard, but you do need to get the front end off the ground (front paddock stand, hoist of a rafter or good old trolley jack plus a mate to hold it steady.)
Once the load is off, loosen all the clamp bolts in the yokes, the stem nut/bolt, and the front axle, its also worth loosening the mudguard bolts as well. when everything is loose, start retightening from the bottom up, this will usually line every thing up on its own if the misalignement is small, if its way out you can align everything by eye before you start tightening.
If it makes no difference, you may have a twisted bottom yoke, which is tricky to find for sure without some reasonably accurate measuring gear.
Trust me, I`m an engineer
GarageOfPower.co.uk
Dinnaz
PostPosted: 21:30 - 22 Aug 2005    Post subject: Reply with quote
Cheerz Pete mate.
Did as you said. Straghtened everything up before tightening.
Now is straight as a dye.
Makes a noticeable difference when riding round small bends now, much better feedback
Thanks again mate.
The last post was made 21 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 39.97 Kb
