Draining oil
Ichy
PostPosted: 20:39 - 20 Aug 2005    Post subject: Draining oil Reply with quote
Last bloke who had my bike filled it up with fully synthetic oil. As its an old 'un I don't see the point, its more likely to cause problems than good old mineral. Do I need to flush ALL the oil out to change back to mineral or can it just be a normal oil change?
Simonbt
PostPosted: 20:41 - 20 Aug 2005    Post subject: Reply with quote
What bike? Dont worry about it too much, its not going to do it any damage so it can wait till it needs a change Thumbs Up
Ichy
PostPosted: 20:44 - 20 Aug 2005    Post subject: Reply with quote
Bike is a GSX600F, not worried and not planning to do it straight away, just want to know if I have to get all the synthentic oil out before putting mineral in?
Simonbt
PostPosted: 20:50 - 20 Aug 2005    Post subject: Reply with quote
As long as you have the engine warm(ish) when you drain the oil the remenants of synth that are left wont make any difference. However you wont get all the oil out as some will still be up by the rockers etc.
As far as i know engine flush doesnt do wonders to bike engines so i wouldnt recomend that.
map
Mr Calendar
PostPosted: 21:31 - 20 Aug 2005    Post subject: Re: Draining oil Reply with quote
marki wrote:
...change back to mineral...
For that sort of engine I'd go for a semi-synthetic oil.
Just IMO you understand but I'd only use so called mineral oil in an ancient (and probably non-Japanese) machine.
On an old engine I'd recommend against doing an engine flush as you can dislodge a load of crap that's now part of the engine and cause more problems than it's worth. Bearing in mind some oil pathways are very fine.
As said all IMO, but said from experience.
PostPosted: 20:38 - 21 Aug 2005    Post subject: Reply with quote
Remember to change the filter at the same time, there is usually about 300ml of oil left in there when you drain the sump.
The last post was made 21 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 47.9 Kb
