K&N on a CG125?
veeeffarr
PostPosted: 18:24 - 23 Aug 2005    Post subject: K&N on a CG125? Reply with quote
Hey guys,
Would there be any benefits of fitting a K&N filter to my CG125? Just fancy buying it something nice and an air filter sounds like a good bet! Smile
Toby
instigator
PostPosted: 18:53 - 23 Aug 2005    Post subject: Reply with quote
Did I say someone should take your debit card away from you? Shocked Shocked !!!
No mate...won't do a thing which you'll think's worth the money. Won't make it power wheelie in 3rd gear nor will it 'thank' you for it. Smile
veeeffarr
PostPosted: 19:09 - 23 Aug 2005    Post subject: Reply with quote
Sad Want one
Josh|RD125LC
PostPosted: 21:01 - 23 Aug 2005    Post subject: Reply with quote
It will just make it sound a bit better thats all. No performance enhancement here.
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
fazed
Korn is my hero!
PostPosted: 22:18 - 23 Aug 2005    Post subject: Reply with quote
It will take away the need to replace the standard one at service intervals. And I bet you a K&N isn't much more expensive than a standard honda filter. Thumbs Up
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
PostPosted: 23:27 - 23 Aug 2005    Post subject: Reply with quote
If you totally remove the air box then fit a foam filter, if it gets wet, say when riding in the rain, the filter usually just soaks up the water. The engine is starved of air so it just dies and probably wont fire up until the foam has dried out. It will also mean you might need to tweak the carb a little due to the increased airflow. Other than those, it wont make any improvement, probably wont make it sound better either.
Of course, if you'd like one, buy one. Its your choice, not ours. Wink
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
Robby
Dirty Old Man
PostPosted: 07:56 - 24 Aug 2005    Post subject: Reply with quote
No point on a CG. The stock filter can flow more than enough air.
A price of a K&N may be comparable to a genuine honda one, but who uses genuine parts in a CG? Should be running a £3 pattern air filter, changed when the economy drops below 80mpg.
craigs23
Mr Muscle
PostPosted: 10:14 - 24 Aug 2005    Post subject: Reply with quote
Just buy some K&N stickers instead, would probably give the same performance boost.
veeeffarr
PostPosted: 11:12 - 24 Aug 2005    Post subject: Reply with quote
Heh, cheers for the advice guys...
Might as well ask another question while I'm here.
I have metal prongs coming out of my seat like upside down hooks, is this for a cargo net/other luggage carrying equipment?
Cheers,
Toby
Robby
Dirty Old Man
PostPosted: 11:21 - 24 Aug 2005    Post subject: Reply with quote
Yes, they are for attaching a cargo net or bungees.
Or string in an emergency.
veeeffarr
PostPosted: 11:25 - 24 Aug 2005    Post subject: Reply with quote
Get in, going to purchase the Oxford one at Lunch then,
£4.99 from Halfrauds.
mchaggis
PostPosted: 20:18 - 24 Aug 2005    Post subject: Reply with quote
The air filter on a CG125 is a foam sock, which doesn't get replaced but cleaned and oiled, so there's no cost of replacement anyway. Smile
I must not be a troll...
Mmmm, Guinness
The last post was made 21 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 70.48 Kb
