Punktures
Ritzah
PostPosted: 20:19 - 24 Aug 2005    Post subject: Punktures Reply with quote
Had my second punkture this morning in a week, with a brand new inner tube and tyre on the back, as i was riding my tyre went, i thought i went over some oil or because it was new, it was still bedding in, so i went abit further, and the back of the bike shook all over, almost came off, pulled over, flat tyre, sweet Thumbs Down as anyone come off because off a flat tyre or anything?
cyberglass
PostPosted: 00:17 - 25 Aug 2005    Post subject: Reply with quote
get yourself some tyre slime its a life saver when your far from home
its well worth the £20 and its better than going arse over tit and destroying £500 worth of fairing
JodieWodie
Reflective Banana
PostPosted: 00:23 - 25 Aug 2005    Post subject: Reply with quote
What the heck is that ???
Dives to google..
Aha !! But do these quick-fixey things actually work ?
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
Bomberman
PostPosted: 03:35 - 25 Aug 2005    Post subject: Reply with quote
Goddam. I expected a huge amount from the title. As it is, you just can't spell. Gutted.
JeffT
PostPosted: 09:09 - 25 Aug 2005    Post subject: Reply with quote
punCtures!
argggh! use the spell checker!
Ric
PostPosted: 10:44 - 25 Aug 2005    Post subject: Reply with quote
punctures caused by punks?
Grubby
PostPosted: 10:46 - 25 Aug 2005    Post subject: Reply with quote
Tubed tyres! Christ I ain't used them since the days of my old Z650!
I am me & you are he & we are all together. See how they run like pigs from a gun!
Ritzah This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
JeffT
PostPosted: 11:15 - 25 Aug 2005    Post subject: Reply with quote
Ritzah wrote:
i'll spell punctures like punktures if i want
and ye karma duth suffer
superstacker
PostPosted: 12:24 - 25 Aug 2005    Post subject: Reply with quote
tyre slime is not a quick fix, is a preventtion measure which is well worth the money.
dont confuse it with tyre weld! which is the bain of the tyre fitters life!
PostPosted: 13:40 - 25 Aug 2005    Post subject: Reply with quote
You drove over her hair... Shocked
https://www.jjfotografie.nl/nsj/albums/punk/punk6_001.jpg
Blimey, I hope she is OK!
ali-b
PostPosted: 13:50 - 25 Aug 2005    Post subject: Reply with quote
Tyre slime kinda works...I use it because its convienient. The plugs are pretty good, I've ridden round on tyres with a few plugs in (can't remember how many they recommend you bin the tyre at though), but the plugs take a while to put in and you need a bunch of equipment to do it (stuff you don't normally carry round). The slime lets you get to a garage where they'll bin the tyre anyway Wink
I had 3 punctures in 1 day once, got the 2 I got on the way to work (rear tyre) plugged while I was at work, then I got another one on the way home (front tyre)...figured they were bad luck and got 2 new tyres...they had only been on about 2 weeks at the time...
A.
Steve H
PostPosted: 14:01 - 25 Aug 2005    Post subject: Reply with quote
AND begin sentances in lower case when capitals are the customarily preferred option - You might be relatively new to the forum Ritzah but I can already tell that you're all for living life on the grammatical edge.
I look forward to more of the same punktuational (I just made that word up thanks to your inspirational typographical style) anarchy Thumbs Up
Mellow Yellow
Robin
PostPosted: 15:22 - 25 Aug 2005    Post subject: Reply with quote
Ignoring all the wannabee English teachers in here (and my punktuation Razz )
Sound like you've still got good old fashioned spoked wheels if you are running with inner tubes.
Have a good check of your rim tape (ooer missus Shocked ) it should be sound to stop any rough ends of your spokes from rubbing on the inside of the inner tube and causing punctures.
Also if the insides of your rim is a bit rusty there might be small bits of rust flaking off and holing the tube.
Apart from that it might just be bad luck.
The last post was made 20 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 85.29 Kb
