End of the line
Vin
PostPosted: 18:29 - 27 Aug 2005    Post subject: Reply with quote
Sorry to hear that! Get a beer and forget about it for today. Tomorrow you will be calmer. Or as someone said to me in a similar situtation
Step back and leave it well alone for a day or 2 then have another look,
Good luck
Vin
PostPosted: 20:25 - 27 Aug 2005    Post subject: Reply with quote
Petrol turned off? Sometimes with 2 strokes as they run out (if idling) the revs go up.
Failing that check for the carb being seated correctly to the engine and that the cables are correctly routed (throttle cable).
mrchips
PostPosted: 21:13 - 27 Aug 2005    Post subject: Reply with quote
In my experiance between WD40 a hammer and an air gun any bolt will loose.
Northern Irish? www.nibikers.com
TOM M
PostPosted: 21:45 - 27 Aug 2005    Post subject: Reply with quote
A piece of brilliant advice that has worked wonders for me in the past Thumbs Up
Now owner of a 1200 Bandit
White Noise
Mr Dudwee
PostPosted: 22:06 - 27 Aug 2005    Post subject: Reply with quote
Yokogeri wrote:
I never thought 1 nut could cause so many problems.
Laughing you haven't been spannering long have you! Very Happy
wait untill you have to take header pipes off!
WN
Gazdaman
I did a trackday!!!
PostPosted: 04:25 - 28 Aug 2005    Post subject: Reply with quote
Header pipes can die. That was the reason I had to take the head off the XJ!
One of the head bolts wouldn't come off the XJ. 12mm bolt head, rounded off. So I 'persuaded' an 11mm socket onto it with my 'persuader' (read hammer) and managed to get it off.
I now have a halfords professional 11mm socket, with a rounded nut stuck in it...
Gaz
Nath
PostPosted: 10:24 - 28 Aug 2005    Post subject: Re: End of the line Reply with quote
Yokogeri wrote:
one of the cylinder head nuts that wont come off, me and dad tried every trick in the book even resorting to drilling it. Still it would not come off!
What did you try before drilling it? If it aint rounded off and it hasn't sheared, then surely taking a drill to it is absolute worst case scenario? Thinking
The most stubborn bolt I've yet to come accross was removed by my dad with a hammer and chisel. No, he did not chisel the head off the bolt... He used the chisel so that it turned the bolt(very slowly) till it would come off the rest of the way with mole grips(the chisel destroyed the head). I've not really come accross any other nuts/bolts that wouldn't shift with a 1/2" drive ratchet and alot of shouting and swearing.
Hard livin', hard luck.
PostPosted: 18:14 - 28 Aug 2005    Post subject: Reply with quote
Not put any heat into it? You should give it a good roasting with a blowlamp until it is hot enough to vapourise a drop of oil then try it.
A bit of heat works wonders for seized nuts (except exhaust headers).
Robby
Dirty Old Man
PostPosted: 18:20 - 28 Aug 2005    Post subject: Reply with quote
You'll get the nut out when you put it back on the bike, just wiggle the socket a lot.
Jack_Cheese
PostPosted: 21:33 - 28 Aug 2005    Post subject: Reply with quote
Heating a nut on top of the engine whit it and the fuel tank still in the bike. Swallowing a nugget of potassium sounds less dangerous to me...
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Ichy
PostPosted: 21:44 - 28 Aug 2005    Post subject: Reply with quote
Only if your planning on waving the blowtorch around like an idiot, the usual idea is to just point the flame at the nut Rolling Eyes I use a welding torch, hotter and more focused, never let me down on the worst of rusted up nuts and I've rarely set fire to anything important Laughing
PostPosted: 22:35 - 28 Aug 2005    Post subject: Reply with quote
Well, common sense would dictate you remove the tank first. It doesn't take long and there is nothing like seeing what you are doing to get a job done properly.
ZZRman
PostPosted: 12:05 - 29 Aug 2005    Post subject: Reply with quote
Sadly some people dont have it
Jack_Cheese
PostPosted: 14:32 - 29 Aug 2005    Post subject: Reply with quote
Yokogeri wrote:
I tried to remove the seat to get the tank off but 2 bolts in to the frame under the rear mudguard where rusted beyond recognition (well the bike is 12 years old!)
My last post was based on the above information.
Marki, i'm a bit of a spaz really, so i'd probably blow the damn thing up or lose a valuable part of my anatomy.
Jack
The last post was made 21 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.33 - MySQL Queries: 60 - Page Size: 83.63 Kb
