correct tyre pressure
Major_Grooves
The Doctor
PostPosted: 16:37 - 03 Feb 2003    Post subject: correct tyre pressure Reply with quote
Can anybody tell me what the correct tyre pressure on my bike should be (Cagiva Planet)?
I have Dunlop Sportmax Radial rear 150/60 and front 110/70. Is that enough info? It doesn't tell me anything in the handbook. Confused
Thanks!
About me|@Major_Grooves|My company|Digg|Flickr
andrew
Mister Road Rage
PostPosted: 16:39 - 03 Feb 2003    Post subject: Reply with quote
Doesnt it say on the tyre?
If not check with the tyre manafacturer.
PostPosted: 17:37 - 03 Feb 2003    Post subject: Reply with quote
Sometimes there's a sticker on the frame or swing arm.
WildGoose
White Van Man
PostPosted: 18:32 - 03 Feb 2003    Post subject: Reply with quote
im not sure quite how important the exact tyre pressures are, but ive got the same size tyres as you and i run 32 at the front 36 at the back, but my bike weighs more than yours so i dunno
best check with a dealer or something, i converted mine from the japanese handbook
Major_Grooves
The Doctor
PostPosted: 19:15 - 03 Feb 2003    Post subject: Reply with quote
According to the helpful dunlop page, a Cagiva Planet 125 should have (for a solo rider) 0psi at front and 0psi at the rear. Confused I reckon that's maybe a bit on the low side. I'll maybe phone the garage, or just try 32/36.
Phoenix
Twisted Firestarter
PostPosted: 23:54 - 03 Feb 2003    Post subject: Reply with quote
I'd be inclined to say 28 front, 30 rear. It's a light bike altho they seem like massive tyres....150 rear?! an RVF400 has a 150 rear.
PostPosted: 00:48 - 04 Feb 2003    Post subject: Reply with quote
For the Mito Evo, from the Cagiva workshop manual, front is 1.9 bar and rear is 2 bar (2 bar and 2.2 bar with a pillion)
The RS125 uses a 150 rear tyre as well, and so does the Gilera CX125 we have (except that use a 120 front to go with it)
Major_Grooves
The Doctor
PostPosted: 17:38 - 02 Apr 2003    Post subject: Reply with quote
How much pressure do tyres normally lose in a week? I check them each week (using the garage forecourt machine) and they normally lose about 10 psi in a week of riding. I am currently setting them at 30 front 32 rear.
kev
I Hump Things
PostPosted: 17:41 - 02 Apr 2003    Post subject: Reply with quote
you shouldnt be loosing presure
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Major_Grooves
The Doctor
PostPosted: 17:43 - 02 Apr 2003    Post subject: Reply with quote
So change the valve caps or the tyres? The rear valve cap has a rubber seal, but doesn't make any difference.
May be a stupid question but how much of a "hiss" should the valve give when you release the pump from the tyre. It seems slightly too long to me - doesn't shut off "sharply". Can you oil the valve or something? Confused
kev
I Hump Things
PostPosted: 17:47 - 02 Apr 2003    Post subject: Reply with quote
it should stop straight away. it may be worth getting a vew valve put in. if you go to any tyre place you should be able to get one and its most likely they wont charge you as they only cost a few pence
Major_Grooves
The Doctor
PostPosted: 17:51 - 02 Apr 2003    Post subject: Reply with quote
Cheers kev. I'll do that! Very Happy Cool
Danny
Ask Me About Stoppie School
PostPosted: 19:17 - 02 Apr 2003    Post subject: Reply with quote
That is way too much Shocked When i had my new tyres fitted they kept loosing pressure ( a few psi a week) then my mechanic changed the valve's and they're fine now. I've got an NSR which i think has a 150 rear tyre Confused I run 29psi front 33psi rear
Major_Grooves
The Doctor
PostPosted: 19:16 - 09 Apr 2003    Post subject: Reply with quote
Is it really gonna be cheap to get the valves replaced? Won't they have to remove the rear wheel to do it which will take some time and cost some money?
Danny
PostPosted: 19:22 - 09 Apr 2003    Post subject: Reply with quote
I think it only takes a few mins Confused I'm i'm wrong someone will probably correct me. Like they SHOULD have when i said my rear tyre was a 150, i found out that its a 130 Very Happy
Phoenix
Twisted Firestarter
PostPosted: 19:38 - 09 Apr 2003    Post subject: Reply with quote
replacing valves is easy, ppl i know who've got it done just donate the garage a box of teabags or something Wink
I don't piss about checking my pressure at garages every week, I just press the tyres to check the pressue every now and then you should be able to feel if it's deflated at all.
M1ke
Ped Boi
PostPosted: 19:49 - 09 Apr 2003    Post subject: Reply with quote
Ive been thiking all this time that my RS125 was abnormal because it has such a crazy sized tyre on the rear! Not even my CBR600 has a 150! its a 130 or something like that.
I was looking in a bike shop at the different sized tyres (yes i was bored) thinking that 150 was the widest you could get but they had sizes right the way up to 180.
Anyway... the point being, My RS125 isnt the only freak of nature Laughing
craigT19
Jolly Green Giant
PostPosted: 19:53 - 09 Apr 2003    Post subject: Reply with quote
me ninjas is odd, 37psi front 44psi rear Confused
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
PostPosted: 19:54 - 09 Apr 2003    Post subject: Reply with quote
33psi front, dunno the back Razz
and tyres sizes newbie, i know they do 190, dunno about from that upwards
Phoenix
Twisted Firestarter
PostPosted: 20:07 - 09 Apr 2003    Post subject: Reply with quote
they do 200 section tyres too, the ZX-12R uses them. 150 is quite large for a 125 tho.
kev
I Hump Things
PostPosted: 21:01 - 09 Apr 2003    Post subject: Reply with quote
if you want a valve in ive got a few kicking around and i will stick one in for you
andrew
Mister Road Rage
PostPosted: 00:54 - 10 Apr 2003    Post subject: Reply with quote
Avon do a 250, its called a Venom R250 Smile Now thats a *big* tyre!
That B-King bike Suzuki were thinking about was going to use a rear 250, Metzeler i think.
The last post was made 23 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 115.35 Kb
