Silencers....
superstacker
PostPosted: 20:18 - 28 Aug 2005    Post subject: Silencers.... Reply with quote
Hi guys, i have a VFR400 nc24, with a rather loud race can fitted.
The can is not marked anywhere to suggest off road use or being road legal.
is it possible to buy baffles for the can to make it quiet enough for an mot? if so where?
White Noise
Mr Dudwee
PostPosted: 20:28 - 28 Aug 2005    Post subject: Reply with quote
you'll be wanting something like this
https://www.performanceracingparts.co.uk/dbkill.htm
WN
superstacker
PostPosted: 20:35 - 28 Aug 2005    Post subject: Reply with quote
without knowing my individual can, how do i know if a 15 DB drop is enough to pass the mot? sorry for sounding Biff like but i dont fancy spending money on something if it doesnt work the way i want it to.
Valentino Mossy
PostPosted: 20:40 - 28 Aug 2005    Post subject: Reply with quote
I've just bought a nc30 with a scorpion race can which says "Not for road use Wink ", would that baffle make it legal for road use ?
Seems a cheaper option then buying a road legal can .
Or should i grind the warning off and wear ear plugs and fit a BS stamp ? Wink
mchaggis
PostPosted: 20:42 - 28 Aug 2005    Post subject: Reply with quote
£17 is cheaper than you will find an alternative can for however.
I must not be a troll...
Mmmm, Guinness
superstacker
PostPosted: 20:44 - 28 Aug 2005    Post subject: Reply with quote
if you have a can marked not for road use, then no matter how quiet it is you cant use it on the road!
However would that DB killer make it road legal? as mine has no such markings.
White Noise
Mr Dudwee
PostPosted: 20:48 - 28 Aug 2005    Post subject: Reply with quote
it says upto 15 dB and TBH that is a scrub off of a hell of a lot of pressure. couldn't tell you but i am sure that whatever the attenuation that it actually provides to you exhaust will make a difference in the MOT tester ears, as he/she will see there is some sort of baffle in there and probibly think that its not offencifially loud!
I've just bought a nc30 with a scorpion race can which says "Not for road use ", would that baffle make it legal for road use ?
if it is stamped no for road use then in the eyes of the law then is should not be used on the road, even if it does fulfil the required noise regulations, saying that with one of these in you probably will attract less attention from the fuzz
WN
ZZRman
PostPosted: 12:15 - 29 Aug 2005    Post subject: Reply with quote
Cans must carry a EU mark, like E1 with lots of other markings which indicate the bike or exhaust manufacturer has complied with the regualtions laid out, you'll see them on bikes since the 80s, if the can has no markings then its illegal to use on road.
kb-zxr
PostPosted: 12:31 - 29 Aug 2005    Post subject: Reply with quote
I thought new legislation means that it should be legal unless specifically marked "Not For Road Use", "Competition Use Only", etc.
If you buy a baffle thing you could polish out the illegal stamping if you had one I suppose.
PostPosted: 12:41 - 29 Aug 2005    Post subject: Reply with quote
Depends on what we are talking about. Passing an MOT test is what you are talking about, and the rules for silencers on that were changed a year or 2 back. However, technically that does not make them road legal.
numark1
Scared of girls
PostPosted: 12:46 - 29 Aug 2005    Post subject: Reply with quote
Stick a brillo pad down the exhaust before the MOT. Thumbs Up
Valentino Mossy
PostPosted: 15:22 - 29 Aug 2005    Post subject: Reply with quote
Hmmn, out comes the dremal then Wink
superstacker
PostPosted: 20:01 - 29 Aug 2005    Post subject: Reply with quote
as i said guys i have no markings on it saying whether its legal or not, and im sure the new rules said it didnt have to be e marked due to many exhausts being made outside europe?
superstacker
PostPosted: 20:15 - 29 Aug 2005    Post subject: Reply with quote
i did find this old post which may solve my problems. So long as the info is still accurate.
https://www.bikechatforums.com/viewtopic.php?t=51705&start=0&postdays=0&postorder=asc&highlight=race+mot
The last post was made 21 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 80.1 Kb
