hidden zorst
R6jonny
PostPosted: 23:19 - 03 Sep 2005    Post subject: hidden zorst Reply with quote
weeeeeeeeelll ,
was fiddling about with the R6 tonight , as you do , took the pillion pegs and end can off for some intense cleaning type stuff and ....well.....the bike looks ace with no can and pegs Very Happy
so heres the question.... as the bike is shockingly loud without a can .... anyway to have a can hidden in the bellypan of the bike.
thus having a silenced-ish bike but with the clean look that no pegs and can brings ??
i have absolutely no idea how to do something like this...although im sure it must be do-able aint it ??
any ideas gratefully recieved
jonny
Honda NSR125 - Yamaha R6 - Ducati 748 - Suzuki GSXR750K6/GSXR1000K7/GSXR750K8 - Ducati 848 - Honda SP1 - Triumph Daytona 675
"simply because she is a female and is thus her actions largely make no sense whatsoever by default"
Groove
PostPosted: 23:21 - 03 Sep 2005    Post subject: Reply with quote
got a piccy? Smile Thumbs Up
R6jonny
PostPosted: 23:25 - 03 Sep 2005    Post subject: Reply with quote
i didnt take one no .... digi cam is fooked and was too dark for camera phone sorry ....
instigator
PostPosted: 23:27 - 03 Sep 2005    Post subject: Reply with quote
Doubt it, unless you can hide the same amount of exhaust pipe hidden between the engine and fairing. I've read that the exhaust manifold is a specific length to help it run correctly blah de blah blah.....*insert some technical waffle about back pressure and engine talk*
I doubt it would be feasible, even on your salary.
Razz Wink Laughing
kal9001
PostPosted: 23:31 - 03 Sep 2005    Post subject: Reply with quote
If there room i suppose you could just doa bodge job by cutting a section of the pipework out and wealding the connecting bit ofpipe onto the new end and thus attaching a new stubby can...go for an oval one and put it flat ways then you may have less chance of scrapeing it...
i wander if a custom exzaust company would (depending on your engine configuration) to fit "mini cans" to each down pipe on the way down...i dont know if that describes it well enough, and it could also obstruct the radiator.
just brain storming...
Anyone stupid enough to think we will drag a load of wooden horses full of soldiers into our city is certanley stupid enough to drag all of ours into theirs!
fuzz
PostPosted: 10:10 - 04 Sep 2005    Post subject: Reply with quote
Underseat exhaust, about the closest you can get to a hidden pipe.
Jrod
Page 3 Girl
PostPosted: 11:25 - 04 Sep 2005    Post subject: Reply with quote
I was looking into this. (must be a tart thing? Wink)
Closest idea I got was to cut the pipe back a litttle to just where it comes out of fairing and fit a baffle in there. Apparently they make the baffles for drag pipes which will work.
Davo
Davo To The Rescue!
PostPosted: 13:57 - 04 Sep 2005    Post subject: Reply with quote
Jon
You after the same type as Paul (aka R1_lad)?
kal9001
PostPosted: 14:10 - 04 Sep 2005    Post subject: Reply with quote
"Closest idea I got was to cut the pipe back a litttle to just where it comes out of fairing and fit a baffle in there. Apparently they make the baffles for drag pipes which will work."
That would be noisey as hell, and the baffle in pipe would redice the pipe diamiter and thus choke the engine...if you had it so the pipe got wider before the baffle then the baffle could have the same diamiter as the pipe's smallest part, but again the cone would be an amplifier and could make it even more noisey!
as i said if you find a custom can shop maybe they can make something to keep the noise down but not be restrictove and beable to hide it in the fairing...
R6jonny
PostPosted: 14:16 - 04 Sep 2005    Post subject: Reply with quote
Davo wrote:
Jon
yup ..... bike looks so hot wiht no can on the side and hidden in the bellypan is a bit different to underseat Very Happy
you know where R1 lad got his from ??
tatters
Exxon Valdez
PostPosted: 14:18 - 04 Sep 2005    Post subject: Reply with quote
there were a few bikes at the BB with no endcans but they had a db killer type tube inside the pipe which was stamped "speedproducts" on the CBR600F,s the exhaust was completely hidden under the belly pan.
R6jonny
PostPosted: 14:20 - 04 Sep 2005    Post subject: Reply with quote
cheers ill look into that
Davo
Davo To The Rescue!
PostPosted: 14:35 - 04 Sep 2005    Post subject: Reply with quote
Jon, let us know what you find, because I'm interested in a similar style exhaust
Reevo8
PostPosted: 14:37 - 04 Sep 2005    Post subject: Reply with quote
Seach through R1 Lad's/Pauls created threads! In one it says the exhaust had been stolen and where it was purchased from in the USA!
05 ZX10R, (**05 WKR) Very Happy
R6jonny
hmmm , speedproducts only seem to sell levers , and chain guard thingys
found "performance racing parts " which sell Db killers ...only £15 ill get one of them and see if its quiet enough ?
zxr400er ill let ya know how it goes Very Happy
(us tarts gotta stick together ) Very Happy
Reevo8
PostPosted: 14:42 - 04 Sep 2005    Post subject: Reply with quote
https://www.mcmcustom.com/
https://www.mcmcustom.com/Product_1.jpg
Is what I found for his used product for an exhaust! Says it just pushes into header pipe!
tatters
Exxon Valdez
PostPosted: 14:44 - 04 Sep 2005    Post subject: Reply with quote
you can get Db killers of ebay for 99p, they fit 2" cans so might fit in the pipe.
does the R6 have a EXUP valve? if so make sure it is,nt part of the link pipe or this will not work.
R6jonny
PostPosted: 14:48 - 04 Sep 2005    Post subject: Reply with quote
copy cat Razz
sammy , i think they are for R1's but im sure a little fettling and it would fit the 6 .... if so i owe ya a pint Very Happy
cant wait to get hold of something like this though ....the bike looks so good without all the shit bolted on the side Very Happy
just need my seat cowl to arrive now Very Happy o and go get a new tyre cos i burnt out my 010 Very Happy ah well
R6jonny
PostPosted: 14:52 - 04 Sep 2005    Post subject: Reply with quote
cheers for the ebay info ....
R6 doesnt have an EXUP valve afaik definitely not in the link pipe bit if it does...
am gonna email MCM and see if their pipes will fit a 6
will try the ebay dB killer first tho methinks
R6jonny
PostPosted: 21:51 - 04 Sep 2005    Post subject: Reply with quote
well part one is sorted .... bought a dB killer off ebay....when it arrives i will try stuffing it down the pipe Very Happy ooh matron
if thats still too loud then i may get a piece of link pipe cut to length to exit below the peg and baffle that up too
will update as and when
also emailed MCM and await a reply regarding compatability...but will imagine they will say no , which will be handy given they are $249 :O
all the money saved can be used to experiment Very Happy
instigator
PostPosted: 21:54 - 04 Sep 2005    Post subject: Reply with quote
See if no-one buys your duke, can you break it and give me the front fairing? I'd love it on my hornet. Wink
R6jonny
PostPosted: 21:56 - 04 Sep 2005    Post subject: Reply with quote
sure, hows £3500 sound for it Wink
duke looks like itll be the deposit for my next bike at this rate Confused
now whatll it be .....06 R6 or Fireblade 1000RR thingumy
instigator
PostPosted: 22:00 - 04 Sep 2005    Post subject: Reply with quote
Anything but a 06 R6... Sick I'll be brutally honest if you buy one so beware...Wink
I told you on several occasions to get some bloody termi's as well....
PostPosted: 22:03 - 04 Sep 2005    Post subject: Reply with quote
Suspect knocking 6" off the length of the exhaust will have some fairly strange effects on the power delivery.
R6jonny
PostPosted: 22:04 - 04 Sep 2005    Post subject: Reply with quote
lol if termis wernt bloody £800 notes i woulda done
even 2nd hand they are about £300
rather have the bellypan exhaust for my 6 ...MotoGP-issimo Very Happy
The last post was made 21 years, 76 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 134.51 Kb
