magnteic oil plugs?
HurtMePlease This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
tatters
Exxon Valdez
PostPosted: 14:01 - 13 Sep 2005    Post subject: Reply with quote
looks like a good idea for bikes without a oil filter, l would,nt expect it to pick up much though.
PostPosted: 14:04 - 13 Sep 2005    Post subject: Reply with quote
It will pick up the odd shard of metal perhaps... except most of an R6 engine is Aluminium alloy and therefore will not be attracted by magnets.
Sounds a bit like snake oil to me! Smile
PostPosted: 14:07 - 13 Sep 2005    Post subject: Reply with quote
They are a good idea, bikes and cars always used to have them. You will be amazed at the amount of iron filings the things pick up in an apparently normal engine. They worked better in older engines which had a deep sump and sludged out any debris next to the drain bolt. Modern engines and oils tend to keep the stuff in suspension more.
You can get magnetic oil filter covers too, which I thought was a good, innovative idea.
sickpup
Old Timer
PostPosted: 14:52 - 13 Sep 2005    Post subject: Reply with quote
I sell them, about £8.00 each and you would be amazed at the shít they pick up. Also give a good indication of the wear on a gearbox.
kal9001
PostPosted: 16:17 - 13 Sep 2005    Post subject: Reply with quote
wouldnt it be better to have something like that in a better place? im sure the sump doesnt get that much crap in there unless its sat...wouldnt it be better to have a section of pipe that you could put a magnetic ring around...and then have a easy way to clean it...as sureley you loose all the oil every time you need to check/change that...
Anyone stupid enough to think we will drag a load of wooden horses full of soldiers into our city is certanley stupid enough to drag all of ours into theirs!
map
Mr Calendar
PostPosted: 16:24 - 13 Sep 2005    Post subject: Reply with quote
Wasn't there something a while back that you could put in the petrol tank that increased your performance and/or economy? Wasn;t that supposed to be some magnetic like device?
Klause
PostPosted: 16:29 - 13 Sep 2005    Post subject: Reply with quote
My monster has one, I found out when I did an oil and filter change. There was quite abit of metal shards on there, so it does work! Thumbs Up
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
Milo
PostPosted: 16:31 - 13 Sep 2005    Post subject: Reply with quote
You're thinking of Power Pills or something labelled to be an octane booster.
As the fuel and oil *shouldn't* mix there's nothing you can put in the fuel that would make the lubrication system any better.
Shaft drives rule. Razz
Dom_
Points Mean Prizes
PostPosted: 16:48 - 13 Sep 2005    Post subject: Reply with quote
I did a gear box oil change on a mates rs125 and his was covered in shards of metal/crap.
Robby
Dirty Old Man
PostPosted: 17:32 - 13 Sep 2005    Post subject: Reply with quote
You can get magnets to put around fuel lines, the people selling them claim they boost fuel economy.
Snake oil
map
Mr Calendar
PostPosted: 17:40 - 13 Sep 2005    Post subject: Reply with quote
robby wrote:
...magnets to put around fuel lines...
That's probably what I was remembering...something like these things (click link).
lightfoot256
PostPosted: 17:52 - 13 Sep 2005    Post subject: Reply with quote
sounds interesting... Although i'd have to see it to believe it.
Anyone ever bought one of these and found it to be of any use?
sickpup
Old Timer
PostPosted: 17:59 - 13 Sep 2005    Post subject: Reply with quote
As said before I sell them. I also use them on all my own bikes, they also come as standard on most new bikes.
The last post was made 21 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 82.75 Kb
