Plastic wielding
-Savage-
PostPosted: 10:23 - 18 Sep 2005    Post subject: Plastic wielding Reply with quote
The CBR i just bought ( Thumbs Up Very Happy Thumbs Up ) has a bit of damage to one of the pannels, it was dropped in a low speed spill, and has slight scuffs but the right hand front indecator punched through the fairing Confused leaving an indicator shaped hole.
Hol feasable is it for me to rent a plastic wielding kit and reapir it myself? And will a plastic wielded area be strong enough to support an indecator being mounted on it?
ps my bloody spell check hasnt worked for months now! any ideas why?
0ddball
PostPosted: 11:04 - 18 Sep 2005    Post subject: Reply with quote
It resigned because of the shear amount of spelling mistakes? Razz
I'm interested in this plastic welding lark too. I've got my fairing sat in front of me at the moment with more cracks than a crazy paving convention. I was tempted to give it a go with a soldering iron then re-enforce it from behind with a sheet or two of firbeglass.
ZXR750L
Andrewc2oo5zx...
PostPosted: 03:29 - 13 Nov 2005    Post subject: Reply with quote
SOLDERING WILL WORK, JUST HEAT BOTH EDGES UP AND PUSH TOGETHER, OR MELT SMAL PLASTIC SHEETS INTO IT
zxr's and cbr's
SUNDERLAND AFC
-Savage-
PostPosted: 19:00 - 13 Nov 2005    Post subject: Reply with quote
thanks for the info, but i got it sorted a while ago, bought a new fairing off bendy Thumbs Up
gammamanuk
PostPosted: 03:46 - 14 Nov 2005    Post subject: Reply with quote
Get a fibreglass kit,
Get sheets of the matting, and piece back the fairing together or if its just cracked/what not then just piece it back together as i said and put layers of fibreglass matting behind the panel and paste the gooey resin mix onto it, once dry, from the front, fill the lines in and cracks with some off the resin, sand smooth, prime, spray Smile
If you indicator has punched a hole in the fairing or you have missing bits, same as above, patch over the whole hole, then drill through it etc to get your indicator to fit again Thumbs Up Smile
feef
Energiser Bunny
PostPosted: 11:43 - 14 Nov 2005    Post subject: Reply with quote
I've repaired cracks in my bodywork using epoxy resin (eg araldite) with aluminium mesh backing the plastic, to provide some strength and structure to the bond.
much easier, and less messy finish than plastic welding (for an amateur point of view anyway)
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
The last post was made 21 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 49.69 Kb
