Wheelie clips (FAO yams + G)
Visitor Q
$25 whore
PostPosted: 11:23 - 23 Sep 2005    Post subject: Wheelie clips (FAO yams + G) Reply with quote
Sadly i am pretty shite, and i have a habit of bouncing the limiter when im being filmed as im making too much of an effort to carry them.
But the third one in this quadlet is quite nice (the one my avatar is from).
Last one was a power wheelie, hence the shite ness
And yeh i chop the throttle, but the bike does stay steady so that at least vaguely proves what ive said about it hating wheelies. Really Really hates them. Front heavy overly high revving lump that it is.
PostPosted: 11:48 - 23 Sep 2005    Post subject: Re: Wheelie clips (FAO yams + G) Reply with quote
Hmmm, first, get a battery camera person and bette Wink.
For me, high revving is good for wheelies, means you can keep 'em going for longer.
I couldn't really tell from that clip, but maybe try starting clutched wheelies at lower rpm if you can? That way you've got more rpm to play with.
Otherwise, if you want to go further in the same gear, you've got to go higher.
Might be worth getting the bike on a dyno if the power delivery is a bit dodgy - at least so you know what's wrong with it.
You could also consider trying changing up - bikes are often smoother on one wheel in second.
Visitor Q
$25 whore
PostPosted: 11:55 - 23 Sep 2005    Post subject: Reply with quote
Yeh i want to, but when i click it to second in the air at high revs it drops straight to neutral.
And it wont come up before high revs.
I start my wheelies rolling at about 20 ish in first, clutch, blip, out and its up.
But its only about 3k from redline. To start with.
Longest ive held a wheelie on it was about 10 seconds
But i can keep my mates ktm 250 2-stroke on the back wheel pretty much 11ed for whole roads, and go first-second etc (although no one warned me they lurch another foot upright when you do it... first time i did it i was staring at the headlight)
PostPosted: 12:00 - 23 Sep 2005    Post subject: Reply with quote
If it's really 10 seconds, it's pretty decent Thumbs Up.
However I know I've done wheelies that I've thought lasted for ages - watched the video and counted - one thousand and one, one thousand and two, etc - and found it's not been long at all.
Visitor Q
$25 whore
PostPosted: 12:07 - 23 Sep 2005    Post subject: Reply with quote
Yeh, i dont count though so its by ear... So probably closer to 5.
Well at least one with some decent height to it.
Any mug can get the front off the floor by a tiny bit and keep it there for the length of first.
I only rediscovered clutching up about a week ago. Ive been pretty much only doing power wheelies, and theres no comparison. Clutch is better. Feels more stable at height, less chop and see sawing etc. Just bang up, cruise out the revs and try and put it down before the limiter.
Note clips were stregically edited to avoid the crackling overrun noise of the limiter LaughingEmbarassedCrying or Very sad
I try too hard to keep them up when being filmed
Sparks!
Sir Tart-a-lot
PostPosted: 15:55 - 23 Sep 2005    Post subject: Reply with quote
You need to clutch from lower revs. Watch my BP video and hear the revs just drop... if you keep hitting the limiter like that then your bike will go pop, I speak from experience here when I was learning I blew my KTM up by hitting limiter.
You're getting neutral because your wheel isn't high enough at all really to change up. If you can wheely a KTM for a ages at 11 then you should be able to wheely the CBR easily, I found it transfered across easy and sports bikes are smoother/easier to balance out. My KTM has a high balance point and you need to get it straight up there or change gear quick else you start to lose power.
Just keep practicing, but I'd find somewhere better to practice, like a quiet industrial estate or something. Leave the on-road wheelies until you can do them a bit better IMO.
Visitor Q
$25 whore
PostPosted: 17:16 - 23 Sep 2005    Post subject: Reply with quote
True. The ktm was a 2 stroke however so no engine braking when you chop the throttle a tad. Also it was slightly downgeared if that made much difference.
Also i would use industrial areas but my wheelies tend to get rather fast rather quickly and i like to have plenty of run off.
Also as was said i only tend to hit the limiter when im being filmed, as i make so much of an effort to keep them up longer, rather then letting it down just before.
As for better area, that road is literally right outside my doorstep, so when a mate came round i collared him. Its the road EVERYONE goes flat out down anyway, its like the gp out there every sunday morning.
I think what i need is to be mean enough to slow right down on roads and then whack it up. Usually im keeping to about 30 ish and then bringing it up, which is perhaps a tad fast. That is still only 6k and the bike redlines at 15. But i suppose if its slower the revs will build slower to start with.
welshy
PostPosted: 19:00 - 24 Sep 2005    Post subject: Reply with quote
Question, why should the height of the wheely determine whether the bike goes into 2nd or not?
I change at the balance point or on the way up depending on how good the inital 'launch' is!. Ok, I am going from 2nd to 3rd as I clutch up in second at anything between 20 and 50 and changing from 2-3 is easier than 1-2.
Ian.
Big and Clever Surprised
Sparks!
Sir Tart-a-lot
PostPosted: 19:10 - 24 Sep 2005    Post subject: Reply with quote
The gear does select yeah but it often drops down or is a bit dodgy, really want to change gear with wheel a bit higher, not BP as you'll probably flip it..
If you try to change straight away I find that by the time you let off the throttle a bit to change that the wheel drops down...
Maybe it's just me, I'm not really practicing changing gear at the minute, just trying kneeling on seat and going way past BP. That's all I'm concentrating on at the minute really.
Jewell This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Visitor Q
$25 whore
PostPosted: 13:25 - 27 Sep 2005    Post subject: Reply with quote
CBR 6
First just isnt smooth enough. You can /hear/ my throttle hand giving it some when its up, but does the bike move?
Nope.
Im doing that to smooth it out... Shocked
Oh well, im now a student with a very fucked vfr 750 and lots of time. But it has got a sodding hydraulic clutch (and a suspected blown piston ring).
But still, can work on bringing it up from walking pretty much. and rolling burnouts.
Might even throw some new plates into it.
Dischord
PostPosted: 03:36 - 01 Oct 2005    Post subject: Reply with quote
https://media.putfile.com/shortvid32
can hold them longer usually but camera pressure and all Razz you gonna be fixin the vfr yourself?
2012 KTM EXC 250
Sparks!
Sir Tart-a-lot
PostPosted: 07:21 - 01 Oct 2005    Post subject: Reply with quote
Those wheelies are sweet!!! Very slow by the looks of it, just need to get it a bit higher and keep use the rear brake.
Very very nice wheelies though based on how slow they look Cool
Dischord
PostPosted: 15:48 - 01 Oct 2005    Post subject: Reply with quote
thanks man, i just try and clutch it up at the lowest revvs possible (sometimes like 2-3000rpm) so they're only like 5-25mph it's hard to stay in a straight line at that speed though! anyway sorry to topic hijack Laughing
2012 KTM EXC 250
Visitor Q
$25 whore
PostPosted: 16:37 - 01 Oct 2005    Post subject: Reply with quote
Gotta admit those are sound wheelies...
Fast ones are more fun tho Razz
The last post was made 21 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> General Bike Videos All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 101.85 Kb
