| Rob W |
 Rob W World Chat Champion
| bish777 |
 bish777 World Chat Champion
| Jrod |
 Jrod Page 3 Girl
| Rob W |
 Posted: 15:13 - 29 Sep 2005 Post subject: |
Possible, and quite often the jetting is different between cylinders (normally the outer pair match, as do the inner pair).
However I would be more inclined to check the mixture screws and the needle position. Also check that there is not a missing rubber O ring between the caps on the tops of the carbs and the carb bodies themselves (common problem on Bandits).
| Rob W |
| Rob W |
| bidman |
 bidman Crazy Courier
 Posted: 13:19 - 03 Oct 2005 Post subject: |
Hi mate, i see you have a micron end can on your bike have you had a dyno jet kit fitted and had it dyno'd to suit as this usualy sorts out any runing problems on the zxr400's when you fit a different end can it needs the dyno jet kit to so that you can adjust the needles and sort out the mixtures etc... but you sound like you know your stuff so just ignore me if youve already done this, cheers Dan  ____________________ Don't ride it, RAG IT!! |
| Rob W |
 Posted: 15:10 - 03 Oct 2005 Post subject: |
I know bikes can need re-jetting if a race can is fitted, but it had that on before the accident and it NEVER did what it's doing now. Ever since the accident it's been running shite.
 ____________________ '90 TS50 > '04 Senda 125 > '91 ZXR400 > '90 CB-1 > '04 GSX-R1000 > '96 Bandit 600 > '89 ZXR750 H1 > '96 GSX-R750 SRAD > '98 RR-W Fireblade > '98 T595 Daytona > '03 Hornet 900 > '04 Fireblade > '16 GSX-S1000F (x2) > '23 XSR900 |
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 17:24 - 03 Oct 2005 Post subject: |
I think Keith could be right about the mixture, but you may also have an inlet leak. When you are riding along, take the revs to about 10k in 3rd or 4th, then shut the throttle, and with out braking, let the bike slow. Tell us what you hear.  |
The last post was made 21 years, 24 days ago. Instead of replying here, would creating a new thread be more useful? |
