Serious ZXR400 problems
Rob W
PostPosted: 13:13 - 29 Sep 2005    Post subject: Serious ZXR400 problems Reply with quote
Well, as some of you may know I got knocked off my ZXR a couple of months back, and ever since it hasn't run correctly. Firstly the head gasket blew shortly after the crash and then I've started having idle/throttle problems.
Basically at around 4-7000 revs it 'chugs' as if it's running out of fuel, but above and below this it's fine. Also it will not idle AT ALL, if I set it to idle when I blip the throttle it goes up the rev counter and then as it drops back down it 'hangs up' at around 2000rpm for about 10-15 seconds before dropping back to it's idle speed. If I set it to not idle, the 'hang up' is non existent. I've had the carbs off, checked the diaphragm's and pilot's, cleaned them and checked the rubber mounts. Even replaced all the HT leads and one of the plug caps that gave a different resistance reading and it's done nothing.
If anyone's got any ideas they would be very much appreciated as I'm getting to the end of my tether now.
bish777
PostPosted: 13:31 - 29 Sep 2005    Post subject: Reply with quote
Having a knock can loosen up all the dirt and rust at the bottom of your fuel tank.
Youll need to get your carbs of and clean them.
Invest in an inline fuel filter-a high flow metal gauze one.
GSXR1100J
Jrod
Page 3 Girl
PostPosted: 13:35 - 29 Sep 2005    Post subject: Reply with quote
The hanging at 2000 revs or so for a sec is normal, nearly every ZXR i've ridden does it.
The 'chugging' is probally the mixture giving you a flat spot. if it was fuel blockage it wouldn't rev cleanly the rest of the way.
Rob W
PostPosted: 14:47 - 29 Sep 2005    Post subject: Reply with quote
Is it possible that I have the wrong size main jet in number 1? Seeing as when I did the head gasket, I cleaned the pistons and barrels up and number 1 had been running rich. I then balanced the carbs and it's still doing it. I checked it by changing the plugs over and it's still running rich on that cylinder, and the plug that was in number 1 is now fine, whereas the number 2 plug that I swapped it with is showing signs of a rich mixture.
PostPosted: 15:13 - 29 Sep 2005    Post subject: Reply with quote
Possible, and quite often the jetting is different between cylinders (normally the outer pair match, as do the inner pair).
However I would be more inclined to check the mixture screws and the needle position. Also check that there is not a missing rubber O ring between the caps on the tops of the carbs and the carb bodies themselves (common problem on Bandits).
Rob W
PostPosted: 18:26 - 29 Sep 2005    Post subject: Reply with quote
Well cheers for all the replies people, gonna be stripping the carbs down fully at the weekend, so hopefully I'll be able to find out what it is doing it. Really quite annoying cos it makes the bike a pain in the arse to ride.
Rob W
PostPosted: 12:32 - 03 Oct 2005    Post subject: Reply with quote
Well, just ordered a set of carbs for £82 and a new air filter and if this doesn't sort it out I'm going to be putting a sledgehammer through it.
bidman
PostPosted: 13:19 - 03 Oct 2005    Post subject: Reply with quote
Hi mate, i see you have a micron end can on your bike have you had a dyno jet kit fitted and had it dyno'd to suit as this usualy sorts out any runing problems on the zxr400's when you fit a different end can it needs the dyno jet kit to so that you can adjust the needles and sort out the mixtures etc... but you sound like you know your stuff so just ignore me if youve already done this, cheers Dan Thumbs Up
Don't ride it, RAG IT!!
Rob W
PostPosted: 15:10 - 03 Oct 2005    Post subject: Reply with quote
I know bikes can need re-jetting if a race can is fitted, but it had that on before the accident and it NEVER did what it's doing now. Ever since the accident it's been running shite.
Mad
Barry_M2
PostPosted: 17:24 - 03 Oct 2005    Post subject: Reply with quote
I think Keith could be right about the mixture, but you may also have an inlet leak. When you are riding along, take the revs to about 10k in 3rd or 4th, then shut the throttle, and with out braking, let the bike slow. Tell us what you hear. Wink
The last post was made 21 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 65.44 Kb
