Peugeot Speedfight Problems
Skiba
PostPosted: 17:08 - 29 Sep 2005    Post subject: Peugeot Speedfight Problems Reply with quote
Hi,
I just went and tried to start my bike and theres no ignition Shocked It wont kickstart either...Anyone know what the problem may be? This hasnt happened before...
Thanks
Lee
Marci
PostPosted: 18:06 - 29 Sep 2005    Post subject: Reply with quote
Check battery voltage with a multimeter for starters.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Skiba
PostPosted: 18:31 - 29 Sep 2005    Post subject: Reply with quote
Ive checked the battery and its kicking out some power still Confused dunno what else it could be, the fuse looks fine..
Andy C
Tree Seeking Missile
PostPosted: 22:17 - 29 Sep 2005    Post subject: Reply with quote
what the ignition makes no sounds at all? i found with my speed fight just leave it for 10 mins then come back and normally was much easier to start! always a bitch in winter though!
Skiba
PostPosted: 22:23 - 29 Sep 2005    Post subject: Reply with quote
Yep the ignition is totally dead, Think its something to do with the immobiliser because the red light isnt on Confused
yambabe
PostPosted: 01:21 - 30 Sep 2005    Post subject: Reply with quote
Apparently if your battery has gone under 9v your immobiliser will kick in, and the only way to get it to start will be to put a set of jump leads on it (make sure it's switched off when you connect the other battery, and connect the +ve first). It should start, and once the battery has charged up it will be OK.
If your immobiliser has kicked in, that will explain why your kickstart doesn't work either but boosting your battery should sort it.
The last post was made 20 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 48.19 Kb
