Best 2 stroke oil for NSR
Danny
Ask Me About Stoppie School
PostPosted: 11:18 - 22 Feb 2003    Post subject: Best 2 stroke oil for NSR Reply with quote
Hi Very Happy
What 2-stroke oil would you guys recommend for a Honda NSR (2001) Question Also what chain lube is good for that bike? I've got that J&S one, but it flies off Crying or Very sad
Thx, Very Happy
Danny
Wingchunal
PostPosted: 11:20 - 22 Feb 2003    Post subject: Reply with quote
Castrol TTS is good but the most expensive from £8.99 -£11.00 depending on the shop!
What j&s oil u got?
Robby
Dirty Old Man
PostPosted: 11:21 - 22 Feb 2003    Post subject: Reply with quote
Castrol TTS for 2 stroke oil, whatever you want for chain lube, if it flies off your probly overlubing, or spinning the wheel round too fast when you spray it on. Try castrol chain wax if you want non fling. Halfords sell it.
Danny
PostPosted: 11:55 - 22 Feb 2003    Post subject: Reply with quote
I got the 'Doctor bike' Heavy duty chain lub
McJamweasel
BCF Junkie
PostPosted: 12:47 - 22 Feb 2003    Post subject: Reply with quote
Apart from the mess it leaves on your wheel having the lube fling off aint a bad thing. As it goes itll also take grit etc with it. Just make sure you do lube it often tho, cos you dont want it buggereing up like mine did and havng the teeth of the front sprocket. Embarassed
Danny
PostPosted: 12:58 - 22 Feb 2003    Post subject: Reply with quote
Well the guy I bought the bike off managed to wear the chain down in one year and he only did 3000 miles in that year. So I have to replace the chain and the sprockets Crying or Very sad My sprockets are so pointy that you could use them as those ninja Frisbee weapons Very Happy
McJamweasel
BCF Junkie
PostPosted: 13:01 - 22 Feb 2003    Post subject: Reply with quote
Well I managed to do this to my sprocket in less than a year, although I probably did more than 3000.
https://www.alfa-pages.co.uk/temppicture/cols_sprocket.jpg
Embarassed Embarassed
Kris
PostPosted: 14:01 - 22 Feb 2003    Post subject: Reply with quote
Best 2-stroke oil I've found is Mobil 1 2-stroke racing oil. Available at most Esso petrol stations Very Happy
Worst oil I've tried is Halfords 2-stroke Confused not good
www.prisonplanet.com
Danny
PostPosted: 14:34 - 22 Feb 2003    Post subject: Reply with quote
Hey McJamweasel that is pritty bad, did u drive everyday through a sandy beach or something?
McJamweasel
BCF Junkie
PostPosted: 16:19 - 22 Feb 2003    Post subject: Reply with quote
No, just most days for 4 months(ish) without lubing it. Then one day the teeth all snapped off. That was not fun!
McJamweasel
BCF Junkie
PostPosted: 18:59 - 22 Feb 2003    Post subject: Reply with quote
An update on the 2 stroke thing. Ive just been and bought some today, I was getting Silkolene Comp2 Plus fully synth. The bloke behind the counter told me not to bother on a 125. He reckons that the semi-synth stuff is ok so thats what I bought. Saved me £4 as well. BTW, this bloke does know what hes talking about as well.
Doddmaster
PostPosted: 19:02 - 22 Feb 2003    Post subject: Reply with quote
I only ever used Castrol TTS in my scooter.
As for chain lube, I have Holts (which i like) and Harley Davidson chain lube (which I use for lubing cables etc)
McJamweasel
BCF Junkie
PostPosted: 03:15 - 23 Feb 2003    Post subject: Reply with quote
TTS is a bit of overkill on a scooter. Cheap of the cheap stuff would be good enough for them cos of the lack of tuning. The bod I spoke to today reckons that TTS/Comp2+ are really more for the 250(+) strokers. He said that he even ran his KR1S on the semi synth for a while with no probs.
Danny
PostPosted: 11:10 - 23 Feb 2003    Post subject: Reply with quote
Right Question
So all of you that own NSR's or did own, what oil do you guys use Question
Input from non-NSR drivers is still welcomed Very Happy
Oh another quick question, i currently am using the Castrol scooter oil which is semi-synth, is it all right to pour in the TTS (fully-synth) with the old oil still inside Question
PostPosted: 12:00 - 23 Feb 2003    Post subject: Reply with quote
I tend to use Comp 2 on the RS125, which some claim isnt a proper fully synthetic 2 squeak oil (I think it claims to be synthetic based).
The time I got the best ever top speed out of the RS was running on TTS. Whether that had anything to do with it or not I am not sure.
If you use better oils then the engine will last longer. On my old AF1 Futura I used semi synthetic oils. When I sold it the engine needed new main bearings (they would have lasted another couple of thousand km), and the RS has already lasted longer without the mains going. However, looking at it one way the savings on 2 stroke oil probably paid for the main bearings (I traded the bike into a dealer, and part of the deal was I dropped the engine out and took it into him, and he did the main bearings, then I put the engine back in again).
As to what engines the 2 squeak oils are intended for, I dont think the engine size is that important. More the state of tune and the specs of the various parts of the engine. The RS is putting out something like 230bhp/l, which is a fairly high state of tune
TJ NSR
PostPosted: 18:36 - 23 Feb 2003    Post subject: Reply with quote
always use fully syntetic...
i use motul 600, only cus i got it free... otherwise its £10
Danny
PostPosted: 18:40 - 23 Feb 2003    Post subject: Reply with quote
free Question How do you get it free Question
Here i am paying like a sucker and your getting it free Mad
PostPosted: 18:43 - 23 Feb 2003    Post subject: Reply with quote
im running some Q8 oil stuff right now, i got a big 4 litre thing of it for about £35. fully synch.
halford stuff is crap
tj works in a bike shop danny
danny, just fill it up with new stuff, you cant drain it and then put new stuff in, cos that would have to run it dry to do that, which is very bad
Danny
PostPosted: 18:49 - 23 Feb 2003    Post subject: Reply with quote
Thx for the info. Very Happy
I'll do that once i get back on the road, i've still got this cold/flu/anthrax thing. Hopefully i'll be back on the road tomorow, then again that is what i said yesterday Very Happy
PostPosted: 18:52 - 23 Feb 2003    Post subject: Reply with quote
damn anthrax Razz
could be stuck with that one for a whole though Very Happy
where u from then danny?
Danny
PostPosted: 18:57 - 23 Feb 2003    Post subject: Reply with quote
Speaking of running the oil dry, i did that once Embarassed
The first day i took it into college, i go 2 drive home(this was that thrusday with all the snow a month back) and the thing keeps dying Question so i kept the revs up and drove away only got 200m and flooded the engine. I thought i was a sign from the Gods not to drive in this snow storm.
I picked it up in the morning when the low oil light finaly came on.
I think they should re-name that light as the 'you've already run out of oil 200m down the road' light Very Happy
Anyway i supose the moral of the story is check the bike over esp oil when you've just bought it.
So far i have not noticed any ill effects from doing that, so far Embarassed
Danny
PostPosted: 18:59 - 23 Feb 2003    Post subject: Reply with quote
Well i live in London, Wimbledon. By family is originally from a small city in the south of Poland.
PostPosted: 19:01 - 23 Feb 2003    Post subject: Reply with quote
your fucking lucky the piston didnt go bang running dry of oil Very Happy
and if your in london, your gonna need to come to boxhill hill meet and stockley. click on usergroups up there ^^^ and then select them, and then click join Very Happy
Danny
PostPosted: 19:08 - 23 Feb 2003    Post subject: Reply with quote
I've already joined, might go over nxt week or the week after. What time do you guys usualy meet there Question
Where is stockley Question
Oh and yea i suppose i am lucky. Very Happy
PostPosted: 19:14 - 23 Feb 2003    Post subject: Reply with quote
stockley is J4 of M4
boxhill when people go meet about 12-2 ish and then go off for a ride and find food somewhere or stay around watching tricks and stuff
The last post was made 23 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 126.01 Kb
