Nsr gear oil problem (or lack of it!)
jamesn
PostPosted: 19:34 - 23 Feb 2003    Post subject: Nsr gear oil problem (or lack of it!) Reply with quote
Just got my nsr serviced yesterday,went out this morning,checked gearbox oil(had to lean the bike over 45 deg before it would show Crying or Very sad min)the oil level was fine before the service,so i topped it up to max,went out again this evening and when i got home the same again(back down to min) Crying or Very sad can anyone please help me! Crying or Very sad Crying or Very sad Crying or Very sad
PostPosted: 19:36 - 23 Feb 2003    Post subject: Reply with quote
Welcome to bikechatforums mate Very Happy
https://www.nsr125.com/gearoil.htm should point you about right for doing the gearbox oil Wink
Robby
Dirty Old Man
PostPosted: 19:38 - 23 Feb 2003    Post subject: Reply with quote
ok..
is the bike standing level and warmed up when you check it (same conditions each time).
are you pulling a lot of wheelies? it could possibly escape out the back.
when you get it in the morning, is there a puddle of oil under it?
check the sump plug is done up good and tight, and check the screw in the side is done up right and there - i dont have an NSR so i'm not sure where the screw is, but its on one side of the crankcases and oil will dribble out through the hole is the level is too high.
if none of that works, go chat to the shop.
jamesn
PostPosted: 19:44 - 23 Feb 2003    Post subject: Reply with quote
yes the bike is warm and standing upright, i havnt pulled any wheelies yet since i got it and it isnt leaking anything,might have to kill someone at the honda shop,thanks for the replies!
PostPosted: 19:55 - 23 Feb 2003    Post subject: Reply with quote
Laughing Laughing
/me points to the nsr bit
how old is the bike?
if its just been serviced (like within about 500 miles) take it back and point this out to them, as they should have picked up on it
did they say anything about there being an oil leak or low oil when you had it serviced?
jamesn
PostPosted: 20:00 - 23 Feb 2003    Post subject: Reply with quote
The bike is brand new,it now has 770 miles on it,I was told everthing went ok when serviced,so still unsure at this point,might change the oil myself and check sump plug etc!
PostPosted: 20:17 - 23 Feb 2003    Post subject: Reply with quote
fuck that, take it back to honda
its first service has just been done, nothing should have gone, let them deal with it
PostPosted: 20:18 - 23 Feb 2003    Post subject: Reply with quote
The oil filler is on the clutch casing, so when you fill it up it will show in the window quickly, and then drop as it finds its way into the gearbox (not talking ages, just a minute or so). So top the oil up as it should be , let it stand for a while and then check it. It should be checked with the bike upright. Make sure you are using the right gear oil (not 2 stroke oil, sorry if that was obvious to you).
If there is not oil leak on the outside then the only place for the oil to go is in through one of the main bearing seals, and the bike would smoke like crazy if it was using that much oil through there
The last post was made 22 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 55.96 Kb
