nc30 carbs...
cyprinis
PostPosted: 11:14 - 04 Oct 2005    Post subject: nc30 carbs... Reply with quote
In an attempt to find the restrictor washers on my nc30, i've been following my haynes manual guide to removing the carbs.
It ain't much good and i'm having trouble getting the carbs off.
how far down do i have to go?
cyprinis
PostPosted: 11:37 - 04 Oct 2005    Post subject: Reply with quote
bump
DucatiEVO
PostPosted: 11:54 - 04 Oct 2005    Post subject: Reply with quote
You should only have to undo the four jubliee clips on the lower rubbers to remove the carbs.
But they can be a nightmare to get back in place, I used a ratchet strap on mine to pull the carbs into place in the end.
Good luck! Smile
aKa: Ducky
cyprinis
PostPosted: 12:03 - 04 Oct 2005    Post subject: Reply with quote
i'm havin trouble getting the rubber tube off of the carbs. do i have to lift the carbs out first? if so, how?
cyprinis
PostPosted: 12:24 - 04 Oct 2005    Post subject: Reply with quote
bump again
cyprinis
PostPosted: 12:48 - 04 Oct 2005    Post subject: Reply with quote
sorted, but now the only problem is gettin it back on...
cyprinis
PostPosted: 14:36 - 04 Oct 2005    Post subject: carbs Reply with quote
does any1 have any helpful tips about putting the carbs back on an nc30, coz i'm about to explode... Brick Wall Doh! Praying
VFR400UK
PostPosted: 15:08 - 04 Oct 2005    Post subject: Reply with quote
loosen the rubers as much as possible, get the front carbs in, then push down on the back till the rear ones go in. cetainly not easy!
cyprinis
PostPosted: 15:21 - 04 Oct 2005    Post subject: Reply with quote
i'm gonna cry in a minute... stupid v4.
cyprinis
PostPosted: 15:55 - 04 Oct 2005    Post subject: Reply with quote
Crying or Very sad
cyprinis
PostPosted: 16:14 - 04 Oct 2005    Post subject: Reply with quote
do you think standing on the carbs to force the rubbers on would be a bad idea? Rolling Eyes
riichy
PostPosted: 16:30 - 04 Oct 2005    Post subject: Reply with quote
hay when every thing els fails its worth a try fella Laughing Thumbs Up
.......... PLOD ............ zx636 2004
DynaMight
PostPosted: 18:05 - 04 Oct 2005    Post subject: Reply with quote
They are a git, I just wiggled them for about 4 hours and it was all peachy Smile
Jamie_ducati
PostPosted: 19:04 - 04 Oct 2005    Post subject: Reply with quote
hate to blow my own trumpet, but usually takes 5 mins.
i find the trick is to fit the rubber collars to the engine side, then screw the lower jubille clips in place.
Then make sure the upper jubille clips are almost fully open.
Then apply a small (AND I MEAN SMALL) amount of lubricant, e.g. machine oil or even washing up liquid to the insides of the rubber collars.
Then start with the front right carb (as viewed from seat) - TIP- The choke mechansim must be at the front - Once the front right carb is loosely positioned, next line up the front left, then push those into the rubber collars, then swing the 2x rear carbs down and push those into position too. Once all 4 are lined up, push the carbs all the way into the collars and tighten the upper jubilee clips.
hope this helps
Jamie
Jamie
Time for eDUCATIon
cyprinis
PostPosted: 19:06 - 04 Oct 2005    Post subject: Reply with quote
sorted it.
thats an absolute bitch of a job. i'm never removing v4 carbs again...
till the next time Rolling Eyes
The last post was made 21 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 82.92 Kb
