sh*t nsr alert!
matphillipsuk
PostPosted: 17:26 - 06 Oct 2005    Post subject: sh*t nsr alert! Reply with quote
right here we go more crap with the nsr, ive got a couple more problems, these are, that under all types of breaking the bike feels like it weaving. ive just put new pads in and they are def in the right way not back to front or anything . any one any ideas on what that is?
the second is that when going round corners and ond straights ie everywhere the front feels like its bobbing up and down alos knocking at most times. im thinking fucked steering head bearing but when i tested this by checking movement in the forks i coulnt detect any? any ideas?
cheers
alains
PostPosted: 17:30 - 06 Oct 2005    Post subject: Reply with quote
sorry , i will be happy to help , but i have not catch everything . could you explain a bit better without abbreviation (because i am french) Very Happy
matphillipsuk
PostPosted: 17:38 - 06 Oct 2005    Post subject: Reply with quote
basicly the bike under all types of breaking feels like it is weaving. i have just put new pads in and they are in the right way not back to front or anything. does any one have any ideas on what that is?
the second is that when going round corners and on straights the front feels like its loose and it also creates a knocking sensation at most times. i think that it is a fucked steering head bearing but when i tested this by checking movement in the forks i coulnt detect any? any ideas?
cheers
feef
Energiser Bunny
PostPosted: 17:51 - 06 Oct 2005    Post subject: Reply with quote
underdamped forks (check fork oil)
low tyre pressure
wheel bearings
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
matphillipsuk
PostPosted: 17:57 - 06 Oct 2005    Post subject: Reply with quote
forks have not long had new seals and oils in them. not sure about the front wheel bearings but no movement on the rear when i was tightening the chain the other day. any other ideas?
alains
first of all , did you drain out the air ? do you know how to do it ?
did you take out , clean and grease the right handle axis lever ?
did you scrap a bit with sand paper the surface of your new pads ?
i suggest :
1) take off the bolt of your right handle , clean it with waterproof sandpaper grade 400 . grease it , and put back . this axis is a constant problem on the NSR . when you crash your handle , nothing comes immediatly , then break strongly .
2) replace you break fluid (use dot 4) :
- pump on you handle , stay pressed on , open the drain bit on the caliper (your handle will go own) , stay pressed , close the drain bit
and start again the process .
- watch constantly the level of fluid in the box . after about 20 times and 80cc gone , it will be ok
note : avoiding fluid going everywhere on the ground , use a plastic pipe that you shove on the drain bit and put the other end in a bottle . you will be surprise about the drained fluid colour !
map
Mr Calendar
PostPosted: 17:59 - 06 Oct 2005    Post subject: Reply with quote
With any handling problems I'd always make sure tyres are at the right pressure, not squared and have sufficient tread.
matphillipsuk
PostPosted: 18:10 - 06 Oct 2005    Post subject: Reply with quote
ok cheers will do
NSR150RR
PostPosted: 21:20 - 06 Oct 2005    Post subject: Reply with quote
Under Chains and Spocket
"lose nervousness" I think you mean "acceleration" right?
alains
PostPosted: 21:41 - 06 Oct 2005    Post subject: Reply with quote
yes , sir !
The last post was made 21 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 65.42 Kb
