Making a good earth...
mr.z
PostPosted: 14:44 - 08 Oct 2005    Post subject: Making a good earth... Reply with quote
Finaly got arorund to fiting horns to the third bike they will have been on
Runs off a 20AMP fuse, so its a fair bit, its going to be off a relay and have + running from the batery to relay..
Wanting it to be tidy + it being a high current, whats the best way to make a good earthing point, say off a bolt hole onto the frame?
I know its simple stuff, but i've done smaller bits beofre which didn't have a good enough earth and want to clarify what i'm doing is right Embarassed Rolling Eyes
Ichy
PostPosted: 16:58 - 08 Oct 2005    Post subject: Reply with quote
Tap the hole out to make sure theres no paint in it, sand the nut head to remove all rust or paint, degrease and then for overkill use conductive grease. Same for terminal and bolt.
Is 20amps a lot for a horn?
mr.z
PostPosted: 17:51 - 08 Oct 2005    Post subject: Reply with quote
Twisted Evil Wink
Thanks for the reply...
Yeh its for the compressor, it will run off 24v@10amps so @12v its 20amps...
Another related question...
If a relay is supplying the 20amps power, is the earth only for the switch current? (i.e. bugger all) + do they only draw the power needed to click the switch/relay? (almost none)
Guest
PostPosted: 19:20 - 08 Oct 2005    Post subject: Reply with quote
Yep, your 20 amp current will be through the heavy contacts and earthed at the load (compressor), the current for the actual coil in the relay will be negligable. But you'll still need a 'good' earth for that.
Teaman
PostPosted: 19:35 - 08 Oct 2005    Post subject: Reply with quote
Air horns by any chance?
if so your as daft as me with the neons
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
mr.z
PostPosted: 18:22 - 09 Oct 2005    Post subject: Reply with quote
Yep, they are there to heared not seen Razz
The horn isn't very effective and have needed to use it a couple of times this summer, so thought i'd get off my ass and sort it out...
Sounds better than the frightend mewing kitten horn
neons... saw the pics, not over the top (not my thing) but nicely done (dont do any more though Razz Laughing ) will help you be seen at night and are fairly legalish...
steveh
PostPosted: 15:14 - 10 Oct 2005    Post subject: Reply with quote
Big snail waggon horns are the way Thumbs Up fitted one to mine and its bloody loud, scares me sometimes Razz
Steve.
The last post was made 20 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 53.46 Kb
