Changing clutch lever...
trevoriv
PostPosted: 17:25 - 09 Oct 2005    Post subject: Changing clutch lever... Reply with quote
Just changed the clutch lever on my thundercat and now the bike wont start whilst in gear Sad any ideas why?
White Noise
Mr Dudwee
PostPosted: 17:31 - 09 Oct 2005    Post subject: Reply with quote
probibly something to do with the safety system that stops you from starting the bike while its in gear. is there a switch near the clutch lever that you may have disturbed?
WN
trevoriv
PostPosted: 18:17 - 09 Oct 2005    Post subject: Reply with quote
there is a cable that plugs into the clutch lever housing which is plugged back in ok but i will have a look make sure its in properly.
starts in neautral ok :/
On the Bandit the switch pokes into the lever, so if you just unbolt the lever and pull it out then you snap the tag off the switch.
Suspect it might be the same on the Thundercat.
trevoriv
PostPosted: 19:53 - 09 Oct 2005    Post subject: Reply with quote
thanks for ur help guys, sorted the problem but went out on the bike and my throttle stuck open RIP Thundercat RIP Crying or Very sad
White Noise
Mr Dudwee
PostPosted: 20:04 - 09 Oct 2005    Post subject: Reply with quote
you mean you crashed it in the 1 1/2 hours since you last posted?
WN
The last post was made 20 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 48.2 Kb
